Software Boss
العودة   منتدى المهندس كوم كلية الهندسة > المنتديات الهندسية > الهندسة المدنية - Civil Engineering
الهندسة المدنية - Civil Engineering الهندسة المدنية،استشارات - هندسة الطرق - مساحة - Structural - Geotechnical  - Construction - Materials
ميكانيك التربة
ميكانيك التربة
قديم 01-09-2009, 06:11   #1
المهندس ياسر
المهندس ياسر is on a distinguished road
Angry ميكانيك التربة
Back to home page
Based on part of the GeotechniCAL reference package
by Prof. John Atkinson, City University, London
Soil de******************ion and classification
• Basic characteristics of soils
• Origins, formation and mineralogy
• Grading and composition
• Volume-weight properties
• Current state of soil
• British Standard system
It is necessary to adopt a formal system of soil de******************ion and classification in order to describe the various materials found in ground investigation. Such a system must be comprehensive (covering all but the rarest of deposits), meaningful in an engineering con************ (so that engineers will be able to understand and interpret) and yet relatively concise. It is important to distinguish between de******************ion and classification:
De******************ion of soil is a statement describing the physical nature and state of the soil. It can be a de******************ion of a sample, or a soil in situ. It is arrived at using visual examination, simple tests, observation of site conditions, geological history, etc.
Soil classification is the separation of soil into classes or groups each having similar characteristics and potentially similar behaviour. A classification for engineering purposes should be based mainly on mechanical properties, e.g. permeability, stiffness, strength. The class to which a soil belongs can be used in its de******************ion.
________________________________________
De******************ion and classification
• Soil as an engineering material
• Size range of grains
• Shape of grains
• Composition of grains
• Structure or fabric
Soils consist of grains (mineral grains, rock fragments, etc.) with water and air in the voids between grains. The water and air contents are readily changed by changes in conditions and location: soils can be perfectly dry (have no water content) or be fully saturated (have no air content) or be partly saturated (with both air and water present). Although the size and shape of the solid (granular) content rarely changes at a given point, they can vary considerably from point to point.
First of all, consider soil as a engineering material - it is not a coherent solid material like steel and concrete, but is a particulate material. It is important to understand the significance of particle size, shape and composition, and of a soil's internal structure or fabric.
The term "soil" means different things to different people: To a geologist it represents the products of past surface processes. To a pedologist it represents currently occurring physical and chemical processes. To an engineer it is a material that can be:
built on: foundations to buildings, bridges.
built in: tunnels, culverts, basements.
built with: roads, runways, embankments, dams.
supported: retaining walls, quays.
Soils may be described in different ways by different people for their different purposes. Engineers' de******************ions give engineering terms that will convey some sense of a soil's current state and probable susceptibility to future changes (e.g. in loading, drainage, structure, surface level).
Engineers are primarily interested in a soil's mechanical properties: strength, stiffness, permeability. These depend primarily on the nature of the soil grains, the current stress, the water content and unit weight.
• Aids to size identification
The range of particle sizes encountered in soil is very large: from boulders with a controlling dimension of over 200mm down to clay particles less than 0.002mm (2m). Some clays contain particles less than 1  in size which behave as colloids, i.e. do not settle in water due solely to gravity.
In theBritish Soil Classification System, soils are classified into named Basic Soil Type groups according to size, and the groups further divided into coarse, medium and fine sub-groups:
Very coarse
soils BOULDERS > 200 mm
COBBLES 60 - 200 mm
Coarse
soils G
GRAVEL coarse 20 - 60 mm
medium 6 - 20 mm
fine 2 - 6 mm
S
SAND coarse 0.6 - 2.0 mm
medium 0.2 - 0.6 mm
fine 0.06 - 0.2 mm
Fine
soils M
SILT coarse 0.02 - 0.06 mm
medium 0.006 - 0.02 mm
fine 0.002 - 0.006 mm
C CLAY < 0.002 mm
Soils possess a number of physical characteristics which can be used as aids to size identification in the field. A handful of soil rubbed through the fingers can yield the following:
SAND (and coarser) particles are visible to the naked eye.
SILT particles become dusty when dry and are easily brushed off hands and boots.
CLAY particles are greasy and sticky when wet and hard when dry, and have to be scraped or washed off hands and boots.
Shape of grains
• Shape characteristics of SAND grains
• Shape characteristics of CLAY grains
• Specific surface
The majority of soils may be regarded as either SANDS or CLAYS:
SANDS include gravelly sands and gravel-sands. Sand grains are generally broken rock particles that have been formed by physical weathering, or they are the resistant components of rocks broken down by chemical weathering. Sand grains generally have a rotund shape.
CLAYS include silty clays and clay-silts; there are few pure silts (e.g. areas formed by windblown Lِess). Clay grains are usually the product of chemical weathering or rocks and soils. Clay particles have a flaky shape.
There are major differences in engineering behaviour between SANDS and CLAYS (e.g. in permeability, compressibility, shrinking/swelling potential). The shape and size of the soil grains has an important bearing on these differences.
Shape of grains
SAND and larger-sized grains are rotund. Coarse soil grains (silt-sized, sand-sized and larger) have different shape characteristics and surface roughness depending on the amount of wear during transportation (by water, wind or ice), or after crushing in manufactured aggregates. They have a relatively low specific surface (surface area).
Click on a link below to see the shape
Rounded: Water- or air-worn; transported sediments
Irregular: Irregular shape with round edges; glacial sediments (sometimes sub-divided into 'sub-rounded' and 'sub-angular')
Angular: Flat faces and sharp edges; residual soils, grits
Flaky: Thickness small compared to length/breadth; clays
Elongated: Length larger than breadth/thickness; scree, broken flagstone
Flaky & Elongated: Length>Breadth>Thickness; broken schists and slates
Shape of grains
CLAY particles are flaky. Their thickness is very small relative to their length & breadth, in some cases as thin as 1/100th of the length. They therefore have high to very high specific surface values. These surfaces carry a small negative electrical charge, that will attract the positive end of water molecules. This charge depends on the soil mineral and may be affected by an electrolite in the pore water. This causes some additional forces between the soil grains which are proportional to the specific surface. Thus a lot of water may be held asadsorbed water within a clay mass.
Shape of grains
Specific surface
• Examples
Specific surface is the ratio of surface area per unit wight.
Surface forces are proportional to surface area (i.e. to d²).
Self-weight forces are proportional to volume (i.e. to d³).
Therefore Surface force  1
self weight forces d
Also, specific surface = area  1
 * volume d
Hence, specific surface is a measure of the relative contributions of surface forces and self-weight forces.
The specific surface of a 1mm cube of quartz ( = 2.65gm/cm³) is 0.00023 m²/N
SAND grains (size 2.0 - 0.06mm) are close to cubes or spheres in shape, and have specific surfaces near the minimum value.
CLAY particles are flaky and have much greater specific surface values.
Examples of specific surface
The more elongated or flaky a particle is the greater will be its specific surface.
Click on the following examples:
cubes, rods, sheets
Examples of mineral grain specific surfaces:
Mineral/Soil Grain width
d (m) Thickness Specific Surface
m²/N
Quartz grain 100 d 0.0023
Quartz sand 2.0 - 0.06 d 0.0001 - 0.004
Kaolinite 2.0 - 0.3 0.2d 2
Illite 2.0 - 0.2 0.1d 8
Montmorillonite 1.0 - 0.01 0.01d 80
See also clay minerals
Structure or fabric
Natural soils are rarely the same from one point in the ground to another. The content and nature of grains varies, but more importantly, so does the arrangement of these.
The arrangement and organisation of particles and other features within a soil mass is termed its structure or fabric. This includes bedding orientation, stratification, layer thickness, the occurrence of joints and fissures, the occurrence of voids, artefacts, tree roots and nodules, the presence of cementing or bonding agents between grains.
Structural features can have a major influence on in situ properties.
• Vertical and horizontal permeabilities will be different in alternating layers of fine and coarse soils.
• The presence of fissures affects some aspects of strength.
• The presence of layers or lenses of different stiffness can affect stability.
• The presence of cementing or bonding influences strength and stiffness.
• Origins of soils from rocks
• Weathering of rocks
• Clay minerals
• Transportation and deposition
• Loading and drainage history
Soils are the results of geological events (except for the very small amount produced by man). The nature and structure of a given soil depends on the geological processes that formed it:
breakdown of parent rock: weathering, decomposition, erosion.
transportation to site of final deposition: gravity, flowing water, ice, wind.
environment of final deposition: flood plain, river terrace, glacial moraine, lacustrine or marine.
subsequent conditions of loading and drainage - little or no surcharge, heavy surcharge due to ice or overlying deposits, change from saline to freshwater, leaching, contamination.
All soils originate, directly or indirectly, from solid rocks in the Earth's crust:
igneous rocks
crystalline bodies of cooled magma
e.g. granite, basalt, dolerite, gabbro, syenite, porphyry
sedimentary rocks
layers of consolidated and cemented sediments, mostly formed in bodies of water (seas, lakes, etc.)
e.g. limestone, sandstones, mudstone, shale, conglomerate
metamorphic rocks
formed by the alteration of existing rocks due to heat from igneous intrusions (e.g. marble, quartzite, hornfels) or pressure due to crustal movement (e.g. slate, schist, gneiss).
Weathering of rocks
Physical weathering
Physical or mechanical processes taking place on the Earth's surface, including the actions of water, frost, temperature changes, wind and ice; cause disintegration and wearing. The products are mainly coarse soils (silts, sands and gravels). Physical weathering produces Very Coarse soils and Gravels consisting of broken rock particles, but Sands and Silts will be mainly consists of mineral grains.
Chemical weathering
Chemical weathering occurs in wet and warm conditions and consists of degradation by decomposition and/or alteration. The results of chemical weathering are generally fine soils with separate mineral grains, such as Clays and Clay-Silts. The type of clay mineral depends on the parent rock and on local drainage. Some minerals, such as quartz, are resistant to the chemical weathering and remain unchanged.
quartz
A resistant and enduring mineral found in many rocks (e.g. granite, sandstone). It is the principal constituent of sands and silts, and the most abundant soil mineral. It occurs as equidimensional hard grains.
haematite
A red iron (ferric) oxide: resistant to change, results from extreme weathering. It is responsible for the widespread red or pink colouration in rocks and soils. It can form a cement in rocks, or a duricrust in soils in arid climates.
micas
Flaky minerals present in many igneous rocks. Some are resistant, e.g. muscovite; some are broken down, e.g. biotite.
clay minerals
These result mainly from the breakdown of feldspar minerals. They are very flaky and therefore have very large surface areas. They are major constituents of clay soils, although clay soil also contains silt sized particles.
Clay minerals
Clay minerals are produced mainly from the chemical weathering and decomposition of feldspars, such as orthoclase and plagioclase, and some micas. They are small in size and very flaky in shape.
The key to some of the properties of clay soils, e.g. plasticity, compressibility, swelling/shrinkage potential, lies in the structure of clay minerals.
There are three main groups of clay minerals:
kaolinites
(include kaolinite, dickite and nacrite) formed by the decomposition of orthoclase feldspar (e.g. in granite); kaolin is the principal constituent in china clay and ball clay.
illites
(include illite and glauconite) are the commonest clay minerals; formed by the decomposition of some micas and feldspars; predominant in marine clays and shales (e.g. London clay, Oxford clay).
montmorillonites
(also called smectites or fullers' earth minerals) (include calcium and sodium momtmorillonites, bentonite and vermiculite) formed by the alteration of basic igneous rocks containing silicates rich in Ca and Mg; weak linkage by cations (e.g. Na+, Ca++) results in high swelling/shrinking potential
For more information on mineralogy see Index of /mineralogy
The effects of weathering and transportation largely determine the basic nature of the soil (i.e. the size, shape, composition and distribution of the grains). The environment into which deposition takes place, and subsequent geological events that take place there, largely determine the state of the soil, (i.e. density, moisture content) and the structure or fabric of the soil (i.e. bedding, stratification, occurrence of joints or fissures, tree roots, voids, etc.)
Transportation
Due to combinations of gravity, flowing water or air, and moving ice. In water or air: grains become sub-rounded or rounded, grain sizes are sorted, producing poorly-graded deposits. In moving ice: grinding and crushing occur, size distribution becomes wider, deposits are well-graded, ranging from rock flour to boulders.
Deposition
In flowing water, larger particles are deposited as velocity drops, e.g. gravels in river terraces, sands in floodplains and estuaries, silts and clays in lakes and seas. In still water: horizontal layers of successive sediments are formed, which may change with time, even seasonally or daily.
• Deltaic & ************f deposits: often vary both horizontally and vertically.
• From glaciers, deposition varies from well-graded basal tills and boulder clays to poorly-graded deposits in moraines and outwash fans.
• In arid conditions: scree material is usually poorly-graded and lies on slopes.
• Wind-blown Lِess is generally uniformly-graded and false-bedded.
The current state (i.e. density and consistency) of a soil will have been profoundly influenced by the history of loading and unloading since it was deposited. Changes in drainage conditions may also have occurred which may have brought about changes in water content.
Loading /unloading history
Initial loading
During deposition the load applied to a layer of soil increases as more layers are deposited over it; thus, it is compressed and water is squeezed out; as deposition continues, the soil becomes stiffer and stronger.
Unloading
The principal natural mechanism of unloading is erosion of overlying layers. Unloading can also occur as overlying ice-sheets and glaciers retreat, or due to large excavations made by man. Soil expands when it is unloaded, but not as much as it was initially compressed; thus it stays compressed - and is said to be overconsolidated. The degree of overconsolidation depends on the history of loading and unloading.
Drainage history
Chemical changes
Some soils initially deposited loosely in saline water and then inundated with fresh water develop weak collapsing structure. In arid climates with intermittent rainy periods, cycles of wetting and drying can bring minerals to the surface to form a cemented soil.
Climate changes
Some clays (e.g. montmorillonite clays) are prone to large volume changes due to wetting and drying; thus, seasonal changes in surface level occur, often causing foundation damage, especially after exceptionally dry summers. Trees extract water from soil in the process of evapotranspiration; The soil near to trees can therefore either shrink as trees grow larger, or expand following the removal of large trees.
• Coarse soils
• Fine soils
• Specific gravity
The recommended standard for soil classification is the British Soil Classification System, and this is detailed in BS 5930 Site Investigation.
Coarse soils
• Particle size tests
• Typical grading curves
• Grading characteristics
• Sieve analysis example
Coarse soils are classified principally on the basis of particle size and grading.
Very coarse
COBBLES 60 - 200 mm
Coarse
soils G
medium 6 - 20 mm
fine 2 - 6 mm
S
medium 0.2 - 0.6 mm
fine 0.06 - 0.2 mm
Coarse soils
Particle size tests
The aim is to measure the distribution of particle sizes in the sample. When a wide range of sizes is present, the sample will be sub-divided, and separate tests carried out on each sub-sample. Full details of tests are given in BS 1377: "Methods of test for soil for civil engineering purposes".
Particle-size tests
Wet sieving to separate fine grains from coarse grains is carried out by washing the soil specimen on a 60m sieve mesh.
Dry sieving analyses can only be carried out on particles > 60 m. Samples (with fines removed) are dried and shaken through a nest of sieves of descending size.
Sedimentation is used only for fine soils. Soil particles are allowed to settle from a suspension. The decreasing density of the suspension is measured at time intervals. Sizes are determined from the settling velocity and times recorded. Percentages between sizes are determined from density differences.
Particle-size analysis
The cumulative percentage quantities finer than certain sizes (e.g. passing a given size sieve mesh) are determined by weighing. Points are then plotted of % finer (passing) against log size. A smooth S-shaped curve drawn through these points is called a grading curve. The position and shape of the grading curve determines the soil class. Geometrical grading characteristics can be determined also from the grading curve.
Coarse soils
Both the position and the shape of the grading curve for a soil can aid its identity and de******************ion.
Some typical grading curves are shown in the figure:
A - a poorly-graded medium SAND (probably estuarine or flood-plain alluvium)
B - a well-graded GRAVEL-SAND (i.e. equal amounts of gravel and sand)
C - a gap-graded COBBLES-SAND
D - a sandy SILT (perhaps a deltaic or estuarine silt)
E - a typical silty CLAY (e.g. London clay, Oxford clay)
Coarse soils
A grading curve is a useful aid to soil de******************ion. Grading curves are often included in ground investigation reports. Results of grading tests can be tabulated using geometric properties of the grading curve. These properties are called grading characteristics
First of all, three points are located on the grading curve:
d10 = the maximum size of the smallest 10% of the sample
d30 = the maximum size of the smallest 30% of the sample
d60 = the maximum size of the smallest 60% of the sample
From these the grading characteristics are calculated:
Effective size
d10
Uniformity coefficient
Cu = d60 / d10
Coefficient of gradation
Ck = d30² / d60 d10
Both Cu and Ck will be 1 for a single-sized soil
Cu > 5 indicates a well-graded soil
Cu < 3 indicates a uniform soil
Ck between 0.5 and 2.0 indicates a well-graded soil
Ck < 0.1 indicates a possible gap-graded soil
Coarse soils
The results of a dry-sieving test are given below, together with the grading analysis and grading curve. Note carefully how the tabulated results are set out and calculated. The grading curve has been plotted on special semi-logarithmic paper; you can also do this analysis using a spreadsheet.
Sieve mesh
size (mm) Mass
retained (g) Percentage
retained Percentage
finer (passing)
14.0 0 0 100.0
10.0 3.5 1.2 98.8
6.3 7.6 2.6 86.2
5.0 7.0 2.4 93.8
3.35 14.3 4.9 88.9
2.0 21.1 7.2 81.7
1.18 56.7 19.4 62.3
0.600 73.4 25.1 37.2
0.425 22.2 7.6 29.6
0.300 26.9 9.2 20.4
0.212 18.4 6.3 14.1
0.150 15.2 5.2 8.9
0.063 17.5 6.0 2.9
Pan 8.5 2.9
TOTAL 292.3 100.0
The soil comprises: 18% gravel, 45% coarse sand, 24% medium sand, 10% fine sand, 3% silt, and is classified therefore as: a well-graded gravelly SAND
Fine soils
• Consistency limits and plasticity
• Plasticity index
• The plasticity chart and classification
• Activity
In the case of fine soils (e.g. CLAYS and SILTS), it is the shape of the particles rather than their size that has the greater influence on engineering properties. Clay soils have flaky particles to which water adheres, thus imparting the property of plasticity.
Fine soils
Consistency varies with the water content of the soil. The consistency of a soil can range from (dry) solid to semi-solid to plastic to liquid (wet). The water contents at which the consistency changes from one state to the next are called consistency limits (or Atterberg limits).
Two of these are utilised in the classification of fine soils:
Liquid limit (wL) - change of consistency from plastic to liquid
Plastic limit (wP) - change of consistency from brittle/crumbly to plastic
Measures of liquid and plastic limit values can be obtained from laboratory tests.
Fine soils
Plasticity index
The consistency of most soils in the ground will be plastic or semi-solid. Soil strength and stiffness behaviour are related to the range of plastic consistency. The range of water content over which a soil has a plastic consistency is termed the Plasticity Index (IP or PI).
IP = liquid limit - plastic limit
= wL - wP
Fine soils
In the BSCS fine soils are divided into ten classes based on their measured plasticity index and liquid limit values: CLAYS are distinguished from SILTS, and five divisions of plasticity are defined:
Low plasticity wL = < 35%
Intermediate plasticity wL = 35 - 50%
High plasticity wL = 50 - 70%
Very high plasticity wL = 70 - 90%
Extremely high plasticity wL = > 90%
A plasticity chart is provided to aid classification.
Fine soils
Activity
So-called 'clay' soils are not 100% clay. The proportion of clay mineral flakes (< 2 m size) in a fine soil affects its current state, particularly its tendency to swell and shrink with changes in water content. The degree of plasticity related to the clay content is called the activity of the soil.
Activity = P / (% clay particles)
Some typical values are:
Mineral Activity Soil Activity
Muscovite 0.25 Kaolin clay 0.4-0.5
Kaolinite 0.40 Glacial clay and loess 0.5-0.75
Illite 0.90 Most British clays 0.75-1.25
Montmorillonite > 1.25 Organic estuarine clay > 1.25
Specific gravity
Specific gravity (Gs) is a property of the mineral or rock material forming soil grains.
It is defined as
Method of measurement
For fine soils a 50 ml density bottle may be used; for coarse soils a 500 ml or 1000 ml jar. The jar is weighed empty (M1). A quantity of dry soil is placed in the jar and the jar weighed (M2). The jar is filled with water, air removed by stirring, and weighed again (M3). The jar is emptied, cleaned and refilled with water - and weighed again (M4).
[The range of Gs for common soils is 2.64 to 2.72]
• Volumes of solid, water and air: the soil model
• Masses of solid and water: water content
• Densities and unit weights
• Laboratory measurements
• Field measurements
The volume-weight properties of a soil define its state. Measures of the amount of void space, amount of water and the weight of a unit volume of soil are required in engineering analysis and design.
Soil comprises three constituent phases:
Solid: rock fragments, mineral grains or flakes, organic matter.
Liquid: water, with some dissolved compounds (e.g. salts).
Gas: air or water vapour.
In natural soils the three phases are intermixed. To aid analysis it is convenient to consider a soil model in which the three phases are seen as separate, but still in their correct proportions.
• Degree of saturation
• Air-voids content
The soil model is given dimensional values for the solid, water and air components: Total volume,
V = Vs + Vw + Va
Since the amounts of both water and air are variable, the volume of solids present is taken as the reference quantity. Thus, the following relational volumetric quantities may be defined:
Note also that:
n = e / (1 + e)
e = n / (1 - n)
v = 1 / (1 - n)
Typical void ratios might be 0.3 (e.g. for a dense, well graded granular soil) or 1.5 (e.g. for a soft clay).
The volume of water in a soil can only vary between zero (i.e. a dry soil) and the volume of voids; this can be expressed as a ratio:
For a perfectly dry soil:
Sr = 0
For a saturated soil:
Sr = 1
Note: In clay soils as the amount water increases the volume and therefore the volume of voids will also increase, and so the degree of saturation may remain at Sr = 1 while the actual volume of water is increasing.
Air-voids content
The air-voids volume, Va , is that part of the void space not occupied by water.
Va = Vv - Vw
= e - e.Sr
= e.(1 - Sr)
Air-voids content, Av
Av = (air-voids volume) / (total volume)
= Va / V
= e.(1 - Sr) / (1+e)
= n.(1 - Sr)
Av = n
Av = 0
The mass of air may be ignored. The mass of solid particles is usually expressed in terms of their particle density or grain specific gravity.
Grain specific gravity
Hence the mass of solid particles in a soil
Ms = Vs .Gs .w
(w = density of water = 1.00Mg/m³)
[Range of Gs for common soils: 2.64-2.72]
Particle density
s = mass per unit volume of particles
= Gs .w
The ratio of the mass of water present to the mass of solid particles is called the water content, or sometimes the moisture content.
From the soil model it can be seen that
w = (Sr .e .w) / (Gs .w)
Giving the useful relationship:
w .Gs = Sr .e
Density is a measure of the quantity of mass in a unit volume of material.
Unit weight is a measure of the weight of a unit volume of material.
There are two basic measures of density or unit weight applied to soils: Dry density is a measure of the amount of solid particles per unit volume. Bulk density is a measure of the amount of solid + water per unit volume.
The preferred units of density are:
Mg/m³, kg/m³ or g/ml.
The corresponding unit weights are:
Also, it can be shown that
 = d(1 + w) and
 = gd(1 + w)
• Water content
• Unit weight
It is important to quantify the state of a soil immediately it is received in the testing laboratory and just prior to commencing other tests (e.g. shear tests, compression tests, etc.).
The water content and unit weight are particularly important, since these could change during transportation and storage.
Some physical state properties are calculated following the practical measurement of others; e.g. void ratio from porosity, dry unit weight from unit weight & water content.
Water content
The most usual method of determining the water content of soil is to weigh a small representative specimen, drying it to constant weight and then weighing it again. Drying can be carried out using an electric oven set at 104-105° Celsius or using a microwave oven.
Example: A sample of soil was placed in a tin container and weighed, after which it was dried in an oven and then weighed again. Calculate the water content of the soil.
Weight of tin empty = 16.16 g
Weight of tin + moist soil = 37.82 g
Weight of tin + dry soil = 34.68 g
Water content, w = (mass of water) / (mass of dry soil)
= (37.82 - 34.68) / (34.68 - 16.16)
= 0.169
Percentage water content = 16.9 %
Unit weight
Clay soils: Specimens are usually prepared in the form of regular geometric shapes, (e.g. prisms, cylinders) of which the volume is easily computed.
Sands and gravels: Specimens have to be placed in a container to determine volume (e.g. a cylindrical can).
Example
A soil specimen had a volume of 89.13 ml, a mass before drying of 174.45 g and after drying of 158.73 g; the water content was 9.9 %. Determine the bulk and dry densities and unit weights.
Bulk density
 = (mass of specimen) / (volume of specimen)
= 174.45 / 89.13 g/ml
= 1.957 Mg/m³
[1 g/ml = 1 Mg/m³]
Unit weight
 = 9.81m/s² x  Mg/m³
= 19.20 kN/m³
Dry density
d = (mass after drying) / (volume)
= 158.73 / 89.13
= 1.781 Mg/m³
d =  / (1 + w)
= 1.957 / (1+0.099)
= 1.781 Mg/m³
Dry unit weight
d =  / (1 + w)
= 19.20 / (1+0.099)
= 17.47 kN/m³
Field measurements
Measurements taken in the field are mostly to determine density/unit weight. The most common application is the determination of the density of rolled and compacted fill, e.g. in road bases, embankments, etc.
Note: These methods are covered in detail by BS1377. You should understand the general principle that density is calculated from the mass and volume of a sample. How a sample of known volume is obtained depends on the nature of the soil. You are not expected to remember the details of each method.
The core cutter method
This method is suitable for soft fine grained soils.
A steel cylinder is driven into the ground, dug out and the soil shaved off level. The mass of soil is found by weighing and deducting the mass of the cylinder. Small samples are taken from both ends and the water content determined.
The sand-pouring cylinder method
This method is suitable for stony soils
Using a special tray with a hole in the centre, a hole is formed in the soil and the mass of soil removed is weighed.
The volume of the hole is calculated from the mass of clean dry running sand required to fill the hole.
The sand-pouring cylinder is used to fill the hole in a controlled manner. The mass of sand required to fill the hole is equal to the difference in the weight of the cylinder before and after filling the hole, less an allowance for the sand left in the cone above the hole.
Bulk density
 = (mass of soil) / (volume of core cutter or hole)
• Soil history: deposition and erosion
• Soil history: ageing
• Density index (relative density)
• Liquidity index
• Predicting stiffness and strength from index properties
The state of soil is essentially the closeness of packing of the grains in the range:
Closely packed  Loosely packed
Dense  Loose
Low water content  High water content
Strong and stiff  Weak and soft
The important indicators of the current state of a soil are:
current stresses: vertical and horizontal effective stresses
current water content: effecting strength and stiffness in fine soils
liquidity index: indicates state in fine soils
density index: indicates state of compaction in coarse soils
history of loading and unloading: degree of overconsolidation
Engineering operations (e.g. excavation, loading, unloading, compaction, etc.) on soil bring about changes in its state. Its initial state is the result of processes of erosion and deposition. It is possible for the engineer to predict changes that could result from a proposed engineering operation: changes from the soil's current state to a new future state.
Original deposition
Most soils are formed in layers or lenses by deposition from moving water, ice or wind.
One-dimensional compression occurs as overlying layers are added. Vertical and horizontal stresses increase with deposition.
Erosion
Erosion causes unloading; stresses decrease; some vertical expansion occurs.
Plastic strain has occurred; the soil remains compressed, i.e. overconsolidated.
Subsequent changes
Subsequent changes may occur in the depositional environment: further loading/unloading due to glaciation, land movement, engineering; and ageing processes.
The term ageing includes processes that occur with time, except loading and unloading. Ageing processes are independent of changes in loading.
Vibration and compaction
Coarse soils can be made more dense by vibration or compaction at essentially constant effective stress
Creep
Fine soils creep and continue to compress and distort at constant effective stress after primary consolidation is complete.
Cementing and bonding
Intergranular cementing and bonding occurs due to deposition of minerals from groundwater, e.g. calcium carbonate; disturbance due to excavation fractures the bonding and reduces strength.
Weathering
Physical and chemical changes take place in soils near the ground surface due to the influence of changes in rainfall and temperature.
Changes in salinity
Changes in the salinity of groundwater are due to changes in relative sea and land levels, thus soil originally deposited in sea water may later have fresh water in its pores, such soils may be prone to sudden collapse.
The void ratio of coarse soils (sands and gravels) varies with the state of packing between the loosest practical state in which it can exist and the densest. Some engineering properties are affected by this, e.g.shear strength, compressibility, permeability.
It is therefore useful to measure the in situ state and this can be done by comparing the in situ void ratio (e) with the minimum and maximum practical values (emin and emax) to give a density index D
emin is determined with soil compacted densely in a metal mould
emax is determined with soil poured loosely into a metal mould
Density index is also known as relative density
Relative states of compaction are defined:
Density index State of compaction
0-15% Very loose
15-35 Loose
35-65 Medium
65-85 Dense
85-100% Very dense
Liquidity index
In fine soils, especially clays, the current state is dependent on the water content with respect to the consistency limits (or Atterberg limits). The liquidity index (L or LI) provides a quantitative measure of the current state:
where
wP = plastic limit and
wL = liquid limit
Significant values of IL indicating the consistency of the soil are:
IL < 0 ق semi-plastic solid or solid
0 < IL < 1 ق plastic
1 < IL ق liquid
المهندس ياسر غير متواجد حالياً   رد مع اقتباس
ميكانيك, التربة
مهندس ميكانيك اود ان تقبلوني صديق لكم مهندس علي الدخيل منتدى التعارف - Forum acquaintance 8 04-10-2010 07:48
ميكانيك السيارات ------------ شرح وافى عبقرينـو هندسة السيارات - Automotive Engineering 10 20-03-2010 02:59
كتاب عن دراسة التربة لا تنسى ذكرالله منتدى العلوم والتكنولوجيا - Science and Technology 2 31-12-2009 12:27
مشاكل التربة الانتفاخية المهندس/حماده الهندسة المدنية - Civil Engineering 10 28-10-2009 10:14
تصنيف التربة (توصيف التربة) sayddafso الهندسة المدنية - Civil Engineering 2 28-07-2009 12:14
Bookmark and Share
الساعة الآن 08:41.
أقسام المنتدى
المنتديات العامة | المنتدى الاسلامى - Islamic forum | منتدى التعارف - Forum acquaintance | منتدى العلوم والتكنولوجيا - Science and Technology | منتدى التطوير الذاتي - Self-development | منتدى اللغات - languages forum | منتدى الطلاب - Student Forumt | منتدى الرياضة - Sports Forum | المنتديات الهندسية | الهندسة المعمارية - Architecture | الهندسة المدنية - Civil Engineering | الهندسة الكهربائية - ELECTRICAL ENGINEERING | الهندسة الميكانيكية - Mechanical Engineering | هندسة البترول والتعدين - Petroleum Engineering | برامج هندسية - Engineering programmes | الأبحاث العلمية - Scientific Research | منتدى الكمبيوتر والتكنولوجيا | منتدى البرامج العام | منتدى عالم الجوال | منتدى البرمجة | منتدى الالعاب | منتدى التصميم والجرافكس | منتدى الاسطوانات التجميعية | منتدى التجارة والاعمال | منتدى الشركات المجانية | منتدى البورصه | منتدى الاقترحات | منتدى الاقتراحات والشكاوى | منتدى خاص بالادارة والمشرفين | منتدى تصميم المواقع | منتدى الوظائف والتوظيف - Jobs and employment | المنتدى العام - Public Forum | كتب هندسة - Engineering books | منتدى المجلات الهندسية - Engineering magazine | هندسة السيارات - Automotive Engineering | دورات هندسية - Engineering courses | هندسة التبريد والتكييف | هندسة الطيران | الهندسة البحرية | الهندسة الصناعية | السلامة المهنية | اساسيات التصميم المعمارى | الفيديو الاسلامى | منتدي الرسوم المتحركه | منتدى اخبار عالم السيارات | منتدى البرامج الحصرية | قسم اكواد الكاست - برامج الكاست | قسم اجهزة تشخيص الاعطال | قسم صيانة واصلاح وبرمجة الكنترول | قسم برمجة المفاتيح | كتب هندسة السيارات | قسم الهندسة المدنية جامعة الازهر | أعضاء هيئة التدريس | الفرقة الاولى مدنى | الفرقة الثانية مدنى | الفرقة الثالثة مدنى | الفرقة الرابعة مدنى | شعبة إنشاءات | شعبة إنشاءات | شعبة أشغال | شعبة أشغال | شعبة رى وهيدروليكا | شعبة رى وهيدروليكا | طلبات البن كود للسيارات | منتدى الديكور والاثاث - decoration and furniture | منتدى اسرة المهندس - Engineer's family | منتدى الصحة والجمال ورعايه الطفل | منتدى مطبخك - kitchen Forum | منتدى اخر موضة - Latest Fashion | منتدى الاعمال الحرفية المنزلية | الهندسة الطبية - Biomedical Engineering | الهندسة الزراعية - Agricultural Engineering | الهندسة الكيميائية - Chemical Engineering | منتدى سيارات - Cars | منتدى عقارات - Real Estate |
