Software Boss
العودة   منتدى المهندس كوم كلية الهندسة > المنتديات الهندسية > الهندسة الصناعية
مجموعة من مشاريع تخرج لتخصص الهندسة الصناعية
قديم 21-11-2010, 01:23   #11
المتفائل2012
المتفائل2012 is on a distinguished road
افتراضي رد: مجموعة من مشاريع تخرج لتخصص الهندسة الصناعية
Key principles of lean manufacturing and an industrial perspective
السنة الأكاديمية:
2010
Supervisors:
Husam Arman
الطلاب:
Ehab Abu Al-Ouf
Mohammad Al-Araj
Eyad Abu Baker
Mahmmud Daraghmeh
Yousef Al-Sader
القسم:
Industrial Engineering
الملفات:
lmshrw.ppt
The Propose of this project is to contribute to the understanding of lean and increase
the general awareness, also to develop a practical lean manufacturing methodology
and to implement key principles of lean as part of the methodology in real case study.
The project will go through sequential steps as follows :
1. Initial literature review in the broad area of lean manufacturing
2. Identify the key principles and concepts to be utilized in the study
3. Comprehensive literature review
4. Develop an initial framework to address the above issues
5. Pilot study in practice and the potentials of applying lean on site (industrial visits)
6. Refine the framework based on the feedback from point 5
7. Implement the resulted methodology in a real case fully
8. Derive a set of guidelines based on results from theory and practice
Throughout these steps, Field study has been made to several companies which were
evaluated in order to choose the ideal Case study, SPSS software was used to
Analyze the given Data .
MS.Visio Software was used (along with the other known MS Office Software's ) to
draw the Block Diagrams needed and The layout of the targeted Company.
The process of Drawing the Value Stream mapping in order to: Make clear the current
production situation by drawing the material and information flows .
Value stream mapping is a Lean process-mapping method for understanding the
sequence of activities used to produce a product, also a map that outlines the current
and future state of a production system, allowing users to understand where they are
and what wasteful acts need to be eliminated and serve as a critical tool during the
review process and can reveal substantial opportunities to reduce costs, improve
production flow, save time, reduce inventory, and improve environmental
performance. Then the user applies lean manufacturing principals to transition into the
future state .
Designing an improved Layout integrated with the Future designed Value Stream
Map to achieve the smooth flow of production and overcome the problems that comes
from the Current Layout and the un-organized arrangement of Resources .
At the end, Results are discussed and Recommendations has been set to achieve the
Goals of Lean Manufacturing of Customer satisfaction and smooth Flow Production .
التعديل الأخير تم بواسطة Spider King ; 21-11-2010 الساعة 02:44
المتفائل2012 غير متواجد حالياً   رد مع اقتباس
قديم 21-11-2010, 01:30   #12
المتفائل2012
QFD Graduation project
السنة الأكاديمية:
2010
Supervisors:
Ahmed al-Rumahi
الطلاب:
Taha M.Bishtawi
Muhammad G.Tanbour
Mo'ath M.Sultan
القسم:
الملفات:
taha_project_final.docx
The aim of this project is to build a structured approach to product development through the House of Quality (HOQ) with application to carton products in the National Cartoon Industry Company Ltd. (NCI). The project procedure and Quality Function Deployment (QFD) implementation process was started by identifying customer’s requirements and expectations from NCI cartoon products and their importance. Various relationships between these expectations and the corresponding technical requirements to satisfy them were determined in addition to the correlation between technical requirements themselves. To recognize the real differences between NCI products and the Israeli competitor’s products, a planning matrix was designed. This matrix shows in what aspects the NCI products quality is exceeded by the Israeli products in addition to the proposed level of customer’s satisfaction NCI hypothesize to reach. Depending on the importance and relationships between customer’s needs and technical specifications and between technical specifications themselves, the whole HOQ matrix was build. The output of this matrix is a set of scores suggesting the most important technical that should be controlled in order to satisfy the customer’s requirements. After performing HOQ matrix quantitative analysis, it is clear that the quality of glue used and the cutting blades renewal are the most important technical specification that should be controlled and monitored to ensure cartoon products quality toward continuous quality improvements as a part of TQM.
قديم 21-11-2010, 01:54   #13
المتفائل2012
Solution of a trim loss problem
السنة الأكاديمية:
2010
الطلاب:
mohammad Khalil amarne
Sobhi kharoub
shareef daowd
ala’a qeshta
Yazan dyab
القسم:
الملفات:
application/vnd.ms-powerpoint icon
kizzy.ppt
Globalization of competition is forcing all industries to continually reduce costs and develop better products and services in order to sustain a competitive advantage in a changing business environment. New concepts such as lean manufacturing have been introduced to address the above challenges. Enormous opportunities of saving by reducing waste in various areas in manufacturing can be utilized through simple management tools.
This project aims to reduce waste in manufacturing processes that involve cutting processes. The one-dimensional cutting stock or trim problem arises in cutting short units from long ones. In this project, the objectives are to fill demand with as little stock as possible, to reduce trim waste.
An optimization model has been developed as a solution to a specific industrial problem in the Aluminum industry. This was achieved using optimization technique (integer linear programming). This model ensures optimal allocation of resources and reduces waste to minimum (trim loss). Dedicated software for this problem has been developed to provide a user-friendly interface.
The model was applied in a real case at National Aluminum & Profile Co. (NAPCO) in Nablus. The initial results and feedback proved the usefulness of the proposed model and the possibility of customizing the solution to other problem domains.
التعديل الأخير تم بواسطة Spider King ; 21-11-2010 الساعة 02:43
قديم 21-11-2010, 01:55   #14
المتفائل2012
The Hazard Analysis Critical Control Point
السنة الأكاديمية:
2010
Supervisors:
Nidal Y. Dwaikat
الطلاب:
hanin hourani
القسم:
الملفات:
presentation_haccp.ppt
a food safety program developed nearly 30 years ago for astronauts and is applying it to seafood and juice .
It focuses on preventing hazards that could cause food-borne illnesses by applying science-based controls, from raw material to finished products.
Safety of the food supply is key to consumer confidence.
قديم 21-11-2010, 01:56   #15
المتفائل2012
بناء نظام مؤشرات أداء لأقسام كلية الهندسة في جامعة النجاح الوطنية
السنة الأكاديمية:
2010
Supervisors:
Suleiman Z. A-Daifi
الطلاب:
روز عجعج
سميرة شاهين
ميس حجازي
مصطفى حدرب
القسم:
الملفات:
mshrw_ltkhrj_lrD.doc
ان بناء المجتمع الحديث يتطلب منا الأهتمام بالبناء المعرفي للمجتمع والذي يعد التعليم من اهم ركائزه الأساسية، ولذا من الضروري ان نكرس الجهود والطاقات اللازمة لتحقيق طفرة نوعية في التعليم،ولا يقتصر العمل من اجل تحقيقها على جهد المؤسسة الحكومية، بل تقوم على اسس من اللامركزية والشراكة المجتمعية المتزايدة، والتي تتيح الأستفادة العظمى من امكاناتنا الذاتية والتنوع في موارد التعليم وتنمية اقتصادياته ولابد ان يواكب ذلك تنمية بيئية
لتوظف تكنولوجيا المعلومات للارتقاء بالتعليم ، في ظل مجتمع معرفي قادر على توظيف العلوم والمعارف والتكنولوجيا الحديثة لخدمة التنمية الشاملة وقضاياها وعلى التطوير المستمر لأدوات قياس اداء الطالب وجودة اداء المنظومة التعليمية كاملة ومن خلال نظام للاعتماد.
يجمع التخاطب الاجتماعي العالمي المعاصر على ان التعليم الجامعي سيكون ميدان تنافسي بين القوى العالمية، وخصوصا في عالم يزداد فيه الاعتماد المتبادل والترابط بشكل متزايد ،ومع ذلك تتعرض النظم التعليمية للنقد دوما ، حيث تبدو هذه العملية النقدية ظاهرة يشترك فيها الخبراء من اصحاب الرؤى المختلفة ، حيث يرى البعض انه يجب ان يتبنى المجتمع النامي مشروع اصلاحي ، الهدف منه الاخذ بيد التعليم العالي في الدول النامية بحيث يمكن تعديل انحرافاته وجعله يسير بخطى متوازية نحو التقدم العلمي للدول ذات الترتيب الاول في العالم.
تعد الجامعات مؤسسات علمية وتربوية رئيسة، تسعي إلي تحقيق العديد من الأهداف في الجانب الأكاديمي، والبحثي، وتنمية المجتمع؛الأمر الذي أكسبها أهمية في مجال التقدم العلمي والتكنولوجي والخدماتي من خلال ما تقدمه من أبحاث علمية وتربوية في كافة المجالات بما يعود بالفائدة علي الطلبة الخريجين والمجتمع ، مما جعلها تتعرض إلي المزيد من الضغوط لأجل زيادة قدرتها علي التكيف والتطوير بما يتلاءم والسرعة الكبيرة والنمو المتسارع في المعرفة والتكنولوجيا .
ونظرا لإتباع سياسات الباب المفتوح في التعليم العالي في العديد من الدول والذي يعتمد علي التوسع الكمي دون الاهتمام الكبير في التوسع الكيفي والنوعي كان لابد من إجراء عمليات مراجعة لأداء الجامعات والمؤسسات التعليمية ووضع مقاييس نوعية وكمية لأجل تقويم تلك المؤسسات والتأكد من شروط التعليم والتعلم فيها .
إن مؤشرات أداء المؤسسات تنظر إليها المؤسسة الحديثة كإستراتيجية لتحقيق ا لأهداف والنتائج ،ومؤشر قوي للنجاح أو الإخفاق التنظيمي ، لهذا تعتبر بمثابة الترمومتر الطبي للمنشأة من حيث قياس ( الحرارة والضغط وبقية الأمراض الأخرى أو التشخيصات الأخرى ) لصحة المنظمات الحديثة ونجاحها في أداء مهامها على الوجه المطلوب .
يعتبر تحديد مؤشرات الأداء تحديد لمؤشرات الجودة ويعتبر من أهم عمليات قياس الأداء، سواء قياس الإنتاجية أو قياس الخدمات،ومن دونها يصبح نظام الجودة جامداً دون أي تحسينات.
إن هذه المقاييس النوعية والكمية وما وضع لها من مؤشرات ستكون عوناً للمؤسسة التعليمية لحصر البيانات والمعلومات ذات العلاقة بأداء المؤسسة والتي من خلالها يمكن للقائمين على شؤونها معرفة جوانب القوة لتعزيزها ومواقع الضعف لمعالجتها،وبالتالي الحكم على مدى نجاعة أداء المؤسسة ذاتها وتجويد أدائها آخذة بالاعتبار تطور هذا الأداء عبر مراحل عملها زمنياً، ومن ثم مقارنة ذلك مع المؤسسات المماثلة عربياً وعالمياً.
تتكون البيئة الجامعية من جوانب متعددة، وتؤثر في الاداء الجامعي عوامل كثيرة ناهيك عن التفاعل بين هذه العوامل. وان بناء ادوات تقويمية لكل من هذه العوامل، مع الأخذ بالاعتبار إن كل عامل يتكون من مجموعة من المكونات التي تحتوي بدورها على أدوات خاصة بها، عملية شاقة تستلزم الكثير من الوقت والجهد والمال.
ونظرا لأهمية جامعة النجاح بين الجامعات في الوطن العربي حققت جامعة النجاح الوطنية انجازا آخر يضاف إلى سجل انجازاتها المتكررة حيث أن الجامعة تحتل المرتبة الأولى على مستوى فلسطين والعاشرة على مستوى الوطن العربي وال1616 على مستوى العالم من حيث الجامعات ,ولأهمية الانجاز المذكور كان لا بد من تطوير مؤشرات أداء للجامعة للحفاظ على هذه المكانة والارتقاء بها,لذلك قمنا نحن فريق البحث بدراسة العناصر الني تؤثر في عملية التقويم الجامعي ,وتوصلنا إلى إن هذه العناصر هي :
1. الطلبة
2. الهيئات التدريسية
3. الخدمات الطلابية
4. نسب النجاح
5. الخريجون
6. المرافق التعليمية
7. البحث العلمي
قديم 21-11-2010, 01:57   #16
المتفائل2012
تطوير الدليل التشغيلي لقسم الهندسة في البلديات المتوسطة
السنة الأكاديمية:
2010
Supervisors:
Suleiman Z. A-Daifi
الطلاب:
نور نصار
أحمد مفيد
هيثم الحميدي
محمد موقدي
القسم:
تعتبر البلديات هيئات حكم محلي ذات شخصية مستقلة مسؤولة عن إدارة المنطقة الجغرافية الواقعة تحت سيطرتها وتقوم البلديات بتقديم خدمات كثيرة للمواطنين, ويعد قسم الهندسة في البلدية من أهم الأقسام في البلديات والذي يقوم بتقديم خدمات متعددة ومهمة للمواطنين, لكن المشكلة التي تواجه البلديات المتوسطة بشكل عام وقسم الهندسة فيها بشكل خاص هو اعتمادها أسلوب المشافهة في تنفيذ النشاطات والخدمات, وعدم وجود دليل تشغيلي يضم إجراءات عمل محددة وموثقة تبين خطوات تنفيذ كل نشاط من هذه النشاطات يؤدي إلى الكثير من المشاكل ومنها عدم تقديم الخدمات للمواطنين بالشكل المناسب والأفضل لان الكثير من الوقت يضيع في إجراءات عشوائية وليس لها أهمية, وعدم وجود هذا الدليل التشغيلي الذي يمثل مرجعا للموظفين الحاليين والموظفين الجدد في البلدية يؤدي إلى عدم معرفتهم بالأمور الواجب عليهم القيام بها ووقوعهم في مشاكل عديدة عند القيام بتنفيذ النشاطات, وبالتالي فان هذا يؤدي إلى عدم سير العمل بالشكل الصحيح, وعدم تقديم الخدمات للمواطنين بالشكل الأفضل. ومن هنا فانه لا بد من تطوير إجراءات العمل المتبعة في البلديات وتوثيقها بطريقة واضحة ومحددة لتمثل دليلا تشغيليا يشكل مرجعا للموظفين يسهل عملهم وينظم عملية تنفيذ النشاطات, وهذا ما سنهتم به في دراستنا.
قديم 21-11-2010, 02:13   #17
المتفائل2012
تطبيق أداة التقييم المؤسسي لنموذج التميز الأوروبي EFQM
السنة الأكاديمية:
2010
Supervisors:
Suleiman Z. A-Daifi
الطلاب:
عبدالله سباعنة
راية عبدالهادي
ماجد الشكعة
بشار سوداح
القسم:
الملفات:
Graduation_Project_Presentationm7mad_sba3neh.pptx
الهدف الرئيسي من المشروع هو اجراء عملية التقييم الذاتي القياسي وفقا معايير نموذج التميز الاوروبي EFQM علما بان عملية التقييم الذاتي ستتم باستخدام اسلوب ومنطق التقييم رادار RADAR , ويتم من خلال هذه العملية التقييمية تشخيص الوضع الحالي للمؤسسة بالمقارنة مع متطلبات معايير النموذج بهدف تحديد الفجوات وتشخيص ابرز الفرص والمشاريع التطويرية والتحسينية ليتم تنفيذها من قبل المؤسسة في سبيل تطوير منهجياتها وممارساتها لتحسين نائج ادائها باستمرار تحقيقا لرسالة واهداف المؤسسة.
يحتوي المشروع على جزئين : الاول الخاص بمعايير الممكنات ( المنهجيات ) والثاني الخاص بمعايير النتائج , وبحيث يشمل كل جزء على استمارات تقييم كمي ( علامات ) مصممة على مستوى المعيار الفرعي وتشتمل على النشاطات الواردة ضمن المعيار الفرعي المحدد اضافة الى استمارات خاصة بالتقييم النوعي ( الملاحظات التقييمية ) لتشخيص ابرز نقاط القوة وابرز الفرص التحسينية الخاصة بكل معيار فرعي.
وتمت عملية التقييم من قبل مجموعة العمل الخاصة بالمشروع من خلال التقييم الميداني للتحقق من مدى وجود متطلبات نموذح التميز EFQM من منهجيات وممارسات ومدى التطبيق الفعلي لها , من خلال اجراء مقابلات مع قيادة الشركة والاطلاع على الوثائق والادلة المعززة لهذا التطبيق
ويشتمل الكتاب في نهاية كل معيار رئيسي على جداول لاحتساب علامات المعيار الرئيسي من علامات معاييره الفرعية, كما يشتمل في النهاية على جدول يلخص العلامات النهائية للمعايير الرئيسية وآلية احتساب وزنها النسبي لاحتساب العلامة الكلية لمجوعة شركات عنبتاوي / مصنع الزيوت.
التعديل الأخير تم بواسطة Spider King ; 21-11-2010 الساعة 02:42
قديم 21-11-2010, 02:17   #18
المتفائل2012
تطوير هيكل تنظيمي وأوصاف وظيفية ودليل إجراءات لقسم السلامة والصحة المهنية في المنشآت الصناعية والخدماتية
السنة الأكاديمية:
2010
Supervisors:
Suleiman Z. A-Daifi
الطلاب:
سعاد حسان
شيماء عودة
مياسين دعاس
اية حلاوة
القسم:
الملفات:
presentation_final.ppt
تدخل السلامة والصحة المهنية في كل مجالات الحياة فعندما نتعامل مع الكهرباء أو الأجهزة المنزلية فلا غنى عن إتباع قواعد السلامة وأصولها وعند قيادة السيارة أو حتى السير في الشارع, ومن البديهي أيضا أننا بحاجة لها داخل المصانع وأماكن العمل المختلفة وفي المنشآت التعليمية.
لذلك فإن إتباع إرشادات وإجراءات السلامة في كل مكان توفر بيئة آمنة, كما أنها تؤدي إلى حماية العاملين في مواقع العمل المختلفة من الأخطار المهنية المتمثلة بحوادث وإصابات العمل والأمراض ذات الصلة بالمهنة.
ولقد أدى التطور الصناعي الذي شهده العالم إلى ظهور العديد من المخاطر التي ينبغي على الإنسان إدراكها وتجنب الوقوع في مسبباتها، فأماكن العمل المتعددة والمختلفة من ورش, ومصانع, ومختبرات ومعامل تعتبر بيئات عمل تكثر فيها العديد من المخاطر المهنية التي يتعرض لها العاملين مثل درجات الحرارة العالية، ومخاطر الآلات الدوارة والأجهزة الحساسة، ومخاطر التفاعلات السريعة، ومخاطر المواد السامة والغازات المتصاعدة وما إلى ذلك من المخاطر . وبالتالي لقد أصبحت السلامة والصحة المهنية محل اهتمام جميع دول العالم التي تشهد تطورات كبيرة ومتسارعة في شتى المجالات، فهي تهدف إلى حماية القوى العاملة جوهرة عملية التنمية الاقتصادية الشاملة, وإيجاد بيئة عمل آمنة, وسليمة خالية من الأخطار المهنية مما يحقق المزيد من الاستقرار والتطوير لعلاقات العمل بين أطراف الإنتاج مما يساهم في دفع عجلة التنمية.
تعتبر السلامة والصحة المهنية جزءاً لا يتجزأ من مجمل عملية التنمية والتطوير الاقتصادي ومكونة لها، فكلما ارتفعت مستويات النمو الاقتصادي والصناعي بوجه خاص كلما كانت الفرص مهيّأة أكثر لتطوير مستويات السلامة والأمان والصحة المهنية في بيئة العمل وبشكل موازٍ ومساوٍ لها.
وتحتاج الدول العربية عامة وفلسطين خاصة لإعادة بناء وتأهيل البنية التحتية للسلامة والصحة المهنية لتصبح المنشآت قادرة على مواكبة ومجاراة عمليات التطوير والبناء اللازمة التي تتطلبها اشتراطات بيئة العمل الآمنة والسليمة. مما يحتاج إلى تعزيز سبل التعاون والعمل المشترك ما بين الحكومة وبيئات العمل المختلفة.
إضافة إلى ذلك فإن العديد من المنشآت الصناعية والخدماتية لا تولي أهمية لموضوع السلامة والصحة المهنية ولا يوجد ضمن هياكلها التنظيمية وظائف خاصة بالسلامة والصحة المهنية.
التعديل الأخير تم بواسطة Spider King ; 21-11-2010 الساعة 02:33
قديم 21-11-2010, 02:19   #19
المتفائل2012
دراسة مدى ملائمة قانون العمل والعمال الفلسطيني و قانون الخدمة المدنية للعمال في شمال الضفة الغربية وأثره على رضاهم الوظيفي وإنتاجيتهم وجودة الخدمات التي يقدموها.
السنة الأكاديمية:
2010
Supervisors:
Tamer Haddad
الطلاب:
يزن محمود الهدهد
قاسم جمال بدران
بسام عبد اللطيف ابو العدل
حسام محمد سالم
كميل عادل زهران
ضيغم فاروق السفاريني
القسم:
الملفات:
mqdm_lktb_m_sm_lTlb_w_lmshrfyn.pdf
الهندسة الصناعية في العالم العربي
لا تحظى الهندسة الصناعية Industrial Engineering في العالم العربي بقدر كبير من الاهتمام بل وربما الكثير من مؤسساتنا لا تعلم شيئاً عن الهندسة الصناعية. و مع الأسف فإننا نخسر الكثير من الفرص لتحسين أدائنا حيث أن الكثير من عمليات التطوير تحتاج إلى علم الهندسة الصناعية و إلى مهندسين صناعيين. ينبغي الانتباه إلى أن الهندسة الصناعية لا تختص بالشركات الصناعية فقط فالهندسة الصناعية تستخدم في الصناعة والخدمات، في شركات الطيران والمستشفيات. الهندسة الصناعية هي مجموعة من العلوم التي تستخدم لتصميم/تحليل/تطوير النظم/ الخدمات والمنتجات. دعني أضرب أمثلة واقعية لتطبيقات الهندسة الصناعية
أولا: تصميم العمل/المنتج/الخدمة Product / Service design : المهندس الصناعي لا يقوم بحسابات التصميم المعتادة ولكنه يتدخل لجعل التصميم أكثر مناسبة للمستخدم و أيسر في الفهم. فقد نصمم جهاز ما ويكون كافيا لأداء وظيفته بالدقة المطلوبة ولكن لا أحد يريد أن يستخدمه لأن التصميم الخارجي غير مريح للمستخدم.
ثانياً: تحديد الحل الأمثل لبعض المشاكل Optimization: يستخدم المهندس الصناعي علم بحوث العمليات Operations Research للوصول إلى أفضل حل وذلك في المشاكل التي يكون لها عدد كبير من الحلول ولا يمكن للعقل البشري أن يفاضل بينها في زمن مقبول. على سبيل المثال: كيف يتم تحديد الجدول الأمثل للطائرات لتقليل التكلفة، ما هو الحد الأدنى من المخزون، ما هي خطة الإنتاج المثلى التي تحقق أعلى عائد، كيف يتم جدولة غرفة عمليات المستشفى لتقليل وقت الانتظار.
ثالثاً: تحليل بعض العمليات عن طريق دراسة الحركة والوقت Time & Motion Study وعن طريق استخدام المحاكاة Simulation بالحاسوب. فمثلاً لتحديد احتياجنا لعمالة أو معدة جديدة يمكن استخدام دراسة الوقت والحركة والإحصاء. بعض الحالات تكون من التعقيد بحيث يصعب تحليلها رياضياً وفي هذه الحالات قد يكون استخدام المحاكاة بالحاسوب أمر مفيد للغاية.
رابعاً: قدرة المهندس الصناعي على فهم و تحليل Data و التعامل معها بشكل المناسب و طرق الوصول لتك Data في عدة طرق من أهمها الاستبيان او السجلات الرسمية ,وتحليلها واخذ العينات منها واستخدام الطرق و البرامج والقوانين لتحليلها للوصول للهدف الذي و جدت له هذه Data كما سنرى في هذه الدراسة .
مثال: مصنع لديه عدد معين من الأوناش تقوم بنقل المنتجات نصف المصنعة داخل المصنع وقررت إدارة المصنع زيادة الإنتاج بإضافة معدات جديدة. كيف يمكن معرفة الحاجة إلى أوناش جديدة من عدمها .
عندما أذهب إلى السوبر ماركت وأجد الطوابير طويلة ومكان الوقوف غير مريح أتساءل أين المهندسين الصناعيين، وكذلك عندما أذهب إلى طبيب لا يستطيع أن يعطي مواعيد للمرضى وبالتالي يضطرون للانتظار لأوقات طويلة أتساءل ماذا لو استعان الطبيب بمهندس صناعي، عندما ترى المديرين يناقشون الحاجة لعمالة جديدة بناءً على مشاعرهم فتساءل أين المهندسين الصناعيين، عندما ترى جداول العمل أو الإنتاج المعقدة جداً يقوم بها شخص ولا يعرف أحد أن هذه الجداول تتسبب في خسارة عظيمة فتساءل أين المهندسين الصناعيين، عندما تجد أن تصميم الجهاز المصنع محلياً غير مريح للمستخدم فتساءل أين المهندسين الصناعيين في العالم العربي وأيضاً تظهر مشاكل في العمل أو مع العمال أنفسهم مشاكل مادية أو صحية أو مهنية نتساءل أين المهندس الصناعي و قدرة على جلب الراحة للعمال في بيئة العمل .
التعديل الأخير تم بواسطة Spider King ; 21-11-2010 الساعة 02:32
متخصص, مجموعة, مشاريع, الصناعية, الهندسة, تخرج
العنوان: أساسيات الهندسة الصناعية noir الهندسة الميكانيكية - Mechanical Engineering 7 07-10-2011 11:02
تاريخ مهنة الهندسة الصناعية Avatar الهندسة الصناعية 0 01-01-2010 04:30
مبادئ الهندسة الصناعية Avatar الهندسة الصناعية 0 01-01-2010 04:21
تعريف الهندسة الصناعية" م/سامرغازى الهندسة الصناعية 1 25-06-2008 11:24
Bookmark and Share
الساعة الآن 01:34.
أقسام المنتدى
المنتديات العامة | المنتدى الاسلامى - Islamic forum | منتدى التعارف - Forum acquaintance | منتدى العلوم والتكنولوجيا - Science and Technology | منتدى التطوير الذاتي - Self-development | منتدى اللغات - languages forum | منتدى الطلاب - Student Forumt | منتدى الرياضة - Sports Forum | المنتديات الهندسية | الهندسة المعمارية - Architecture | الهندسة المدنية - Civil Engineering | الهندسة الكهربائية - ELECTRICAL ENGINEERING | الهندسة الميكانيكية - Mechanical Engineering | هندسة البترول والتعدين - Petroleum Engineering | برامج هندسية - Engineering programmes | الأبحاث العلمية - Scientific Research | منتدى الكمبيوتر والتكنولوجيا | منتدى البرامج العام | منتدى عالم الجوال | منتدى البرمجة | منتدى الالعاب | منتدى التصميم والجرافكس | منتدى الاسطوانات التجميعية | منتدى التجارة والاعمال | منتدى الشركات المجانية | منتدى البورصه | منتدى الاقترحات | منتدى الاقتراحات والشكاوى | منتدى خاص بالادارة والمشرفين | منتدى تصميم المواقع | منتدى الوظائف والتوظيف - Jobs and employment | المنتدى العام - Public Forum | كتب هندسة - Engineering books | منتدى المجلات الهندسية - Engineering magazine | هندسة السيارات - Automotive Engineering | دورات هندسية - Engineering courses | هندسة التبريد والتكييف | هندسة الطيران | الهندسة البحرية | الهندسة الصناعية | السلامة المهنية | اساسيات التصميم المعمارى | الفيديو الاسلامى | منتدي الرسوم المتحركه | منتدى اخبار عالم السيارات | منتدى البرامج الحصرية | قسم اكواد الكاست - برامج الكاست | قسم اجهزة تشخيص الاعطال | قسم صيانة واصلاح وبرمجة الكنترول | قسم برمجة المفاتيح | كتب هندسة السيارات | قسم الهندسة المدنية جامعة الازهر | أعضاء هيئة التدريس | الفرقة الاولى مدنى | الفرقة الثانية مدنى | الفرقة الثالثة مدنى | الفرقة الرابعة مدنى | شعبة إنشاءات | شعبة إنشاءات | شعبة أشغال | شعبة أشغال | شعبة رى وهيدروليكا | شعبة رى وهيدروليكا | طلبات البن كود للسيارات | منتدى الديكور والاثاث - decoration and furniture | منتدى اسرة المهندس - Engineer's family | منتدى الصحة والجمال ورعايه الطفل | منتدى مطبخك - kitchen Forum | منتدى اخر موضة - Latest Fashion | منتدى الاعمال الحرفية المنزلية | الهندسة الطبية - Biomedical Engineering | الهندسة الزراعية - Agricultural Engineering | الهندسة الكيميائية - Chemical Engineering | منتدى سيارات - Cars | منتدى عقارات - Real Estate |
