قديم 03-11-2008, 07:52
الصورة الرمزية mody256
mody256
(الإدارة)
Cant See Images
Scan your maps directly from Cartopro
· Show on a larger scaled map the circumference of all your other maps
· Find the right coordinate format on the World map
· Add pictures and drawings to your maps
· Show your Maps and Point your data on Google Earth
· Calibration is Easy and accurate in 2 points. 1 minute guaranteed. For very poor quality maps, visual modifications can be made manually
· Large number of Datums available. You can add Datuns manually.
· Click any position on a map to obtain a list of all your other maps where to show this place.
· Allow you to know the exact coverage of map that you have and to open one of them if desired.
· Import and Export multiple Cartopro calibrated maps. You can import or export an entire DVD for example.
· Copy and past maps images between cartopro and other softwares. From Internet or Photoshop for example.
· Create, modify Routes, Tracks and Waypoints by simple clicks. You can manage as many Routes, Tracks and Waypoints your GPS own at the same time.
· Set or modify all parameters of any point in editors of Waypoints Tracks and Routes. (By click on map or by typing on the keyboard) Coordinates, Name, Elevation, Symbols etc ...
· Click in the list of Waypoints Tracks or Routes in edition to open a list of the possible maps where to display them. Click in the list to open the map. All data will remain displayed on the new map.
· Display independently as much of other Waypoints Tracks or Routes that you want. These displayed data can be transferred for edition from a simple click.
· You can see properties of all displayed points by simple click on it.
· Use Waypoints as comments associated with your track. Click then hit "c" on the map to add a comment
· Improve the color and contrast quality of your map by changing the color histogram. Powerful and Simple
· Tool of transformation for almost any list of coordinates into Track or Waypoints. Can be used to convert tables, copy of Internet pages or data files like: OziExplorer, Fugawi, Alpenverein, Kompass, MapSource, CartoExplorer
· Point your positions from Cartopro to Google Earth.
· Use waypoints to calibrate your Map.
· Create Route Plan with comments, references, distances between waypoints, heading (true and magnetic) To use by foot with a compass or just to indicate the way to follow by car ...
· Create Flight Plan with distances between waypoints, heading, magnetic tracks radio frequencys, comments etc.
· Insert images, ************s and drawings on your Maps. You will be able to print them in a pdf file then to transmit the file by e-mail to your companions of race
· Transfer Routes Track and Waypoints files. Cartopro => GPS, GPS => Cartopro
· Re-assembe your maps scanned by pieces.
· Visual environment even for large maps.
· Help at any levels, full of information.
· Printing of the map in A4 or A3 with indexed Grid and Zooms. Visual and useful.
· Tracking software . Interfaces [Nmea 0183, Garmin , Garmin USB]
· Save and display your track while navigate, save mob point - m.o.b. = Man Over Board
· In tracking mode, the following map is opened automatically
· Interactive graphs for Speeds and Altitudes with slopes etc.
· Support common units like English, nautical and European
· Automatic calculation of surface for Tracks. Different units available. Calculate the area of a field, etc
· Automatic calculation of the length of Routes and Tracks. Length of your trip, p�rimeter of a field, etc
· Simulate displacements of several GPS based on the recorded tracks.
· Import and export Cartopro maps with their calibrations. Import and export by list like a whole DVD for exemple.
· Importation of TTQV maps on CD. E xtension .bmp .png .tif .jpg except pny protected format
· Map of the region preselected with easy opening.
· The map of the world allow you to see the position of your maps and to open them by simple clicks on it.
· The map of the world give you an interactive tool to find the right format of your U.T.M. co-ordinates.
· Routes, Tracks and Waypoints are ************ formated. They have markers to allow their treatment in Excel or other spreadsheet tool.
· Symbols are Icons. You can modify them.
· Simple and reliable.
· All is calculated, no approximation. Full accuracy
يمنع وضع أي رابط او مرفق لبرنامج او لعبة ( مكسورة الحماية ) سواء (كراك او سيريل او كيجن او رابط لتبادل الملفات او رابط لموقع آخر أو اي شي قد يخدم هذا المجال
mody256 غير متواجد حالياً
قديم 30-12-2017, 08:49
افتراضي رد: Cartopro Evolution v23.10.2008
#2
الصورة الرمزية ouarsenis
ouarsenis
ouarsenis is on a distinguished road
thankkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkks
ouarsenis غير متواجد حالياً   رد مع اقتباس
cartopro, evolution, v23.10.2008
الساعة الآن 07:42 بتوقيت مسقط
