Lotus Engineering Software All-in-One برامج هندسية
قديم 01-12-2007, 11:22   #1
Talking Lotus Engineering Software All-in-One برامج هندسية
اخواني الكرام مش عارف ها ابدا شرح البرنامج ده من فين عموما الصور هتغنيكم عن شرحي فالبرنامج رائع جدا في التصاميم الخاصه بالسيارات
وارجو من اخي محمد ابو زهره ان يضمها الي موسوعه العملاقه بالمنتدي الخاصه ببرامج السيارات
فور انتهائي من تحميلها كلها وشكرا
وهذا شرح بسيط لها
Lotus Vehicle Simulation provides rapid answers to vehicle performance questions. Virtual vehicles can be put through a range of simulated events including: steady speed operation; acceleration events; emissions cycles; laps of a course. The program can be used to optimise gear and final drive ratios, assess fuel economy sensitvity, and assess powertrain suitability in given vehicle applications.
Computer simulation is now a key part of the automotive development process. lotus engineering software has been developed by automotive engineers whilst using them on many powertrain and vehicle projects at lotus over the past 15 years. The philosophy under-pinning lotus engineering software is to offer simulation tools which enable the user to generate models very quickly, using a mixture of embedded design criteria and well-structured interface functionality.
includes:
Base Engine Analysis Tools v4.02c
Concept Valve Train v2.05g
Engine Simulation v5.06b
Suspension Analysis (Shark/Raven) v4.03c
Vehicle Simulation v3.11f
all ***************ed by SHOCK TEAM
Lotus Base Engine Analysis Tools 4.02c
Lotus Engine Simulation is a state of the art PC-based simulation system for engine performance prediction, combining models for unsteady gas flow in manifold components with those characterising the combustion process. Computer simulation is now a key part of the automotive development process. lotus engineering software has been developed by automotive engineers whilst using them on many powertrain and vehicle projects at lotus over the past 15 years. The philosophy under-pinning lotus engineering software is to offer simulation tools which enable the user to generate models very quickly, using a mixture of embedded design criteria and well-structured interface functionality.
Lotus Concept Valve Train 2.05g
Lotus Concept Valve Train uses template driven data entry to design cam profiles. The motion can be specified from either the cam or valve end of the mechanism. Motion definition is via segmented polynomials with user controlled levels of derivative definition. On-screen results show the profile summary compared to user-definable design limits. The four available mechanism templates cover the majority of conventional valve train systems. Template types are 'Direct Acting', 'Centre Pivot Rocker', 'Finger Follower' and 'Push Rod'. The dynamic analysis mode enables both mechanical of hydraulic tappets to be simulated. Single- or twin-coil mechanical spring models are available, together with a gas spring model which includes mass transfer and variable gas properties. A range of profile definition methods is available. Three standard segmented polynomials provide solutions for typical design including eccentricity-limited profiles and concavity limited profiles. In addition a user-defined polynomial is available with complete control over the number of segments and end constraints. Each segment can have additional mid points the values for which can also be defined in lift or any chosen derivative.
Lotus Engine Simulation 5.06b
Lotus Engine Simulation is a state of the art PC-based simulation system for engine performance prediction, combining models for unsteady gas flow in manifold components with those characterising the combustion process. lotus Engine Simulation is a powerful tool allowing powertrain analysts to develop engine models rapidly, carry out parameter studies and optimisation, providing real time and cost savings. Developed by engineers, who understand the engine development process, it features a clear and intuitive interface allowing the rapid development of simulation models and easy analysis of results. On-line help and comprehensive tutorial files are included with the software which combined with the easy-to-use interface results in an unparalleled learning curve.
Lotus Suspension Analysis 4.03c
Lotus Suspension Analysis provides a simple to use tool for the design and analysis of suspension geometry. Standard suspension types using indivdual default pre-filled templates provide easy creation of kinematic model, in either 2D or 3D modes. lotus Suspension Analysis default template types include, double wishbones, Macpherson struts, trailing arm, semi-trailing arm, pull rod and push rod damper actuation, 'A' frame and 'H' frame. Users can create and distribute their own unique templates. Kinematic results include camber angle, castor angle, toe, kingpin angle, roll centre position, damper ratio, spring ratio, track change, wheelbase change, % anti squat, % anti dive and % Ackermann. The suspension hard points can be picked on screen and simply edited to review changes to the suspension characteristics. Alternative approaches can be used to point editing through on screen dragging. Picking a point and dragging it along one or more axes, the graphical results being updated as you move the point. Points can be moved as a 'group' such that the dimensional relationship of a wishbone can be retained.
Lotus Vehicle Simulation 3.11f
والان اللي روابط التحميل
يمكنك تحميل المجموعه كامله من هنا
او من هنا
وانا لا افضلهما لذا قمت برفع كل برنامج علي حده من هنا
والسلام عليكم ورحمه الله وبركاته
ارجو منكم الدعاء لي بالتوفيق وان يهديني الله ويشف كل امراض المسلمين
آخر مواضيعي 0 Practical Guide to Inspection, Testing and Certification of Electrical Installations
0 Control System Design
0 Modern Physical Metallurgy and Materials Engineering
0 An Introduction to Geotechnical Engineering
0 Essential MATLAB for Engineers and Scientists - 3rd Edition
التعديل الأخير تم بواسطة م/محمد لطفي ; 01-12-2007 الساعة 12:32 سبب آخر: اضافه اخر رابط
قديم 01-12-2007, 11:24   #2
آخر مواضيعي 0 Aerothermodynamics of Gas Turbine Rocket Propulsion, Third Edition (Aiaa Education Se
0 Introduction to Computational Fluid Dynamics
0 ISO 9000 Quality Systems Handbook, Fifth Edition
0 ANSI / ASHRAE / IESNA Standard 90.1 - 2004 User's Manual
0 Digital Logic Design, Fourth Edition
قديم 01-12-2007, 11:26   #3
آخر مواضيعي 0 Health and Safety in Welding and Allied Processes
0 Guide to Design Criteria for Bolted and Riveted Joints, 2nd Edition
0 Radiant Heating and Cooling Handbook
0 Nanoengineering of Structural, Functional and Smart Materials
0 Aerodynamics of the Helicopter
قديم 01-12-2007, 08:28   #4
م/عمرو السيد is on a distinguished road
يسعدني اخي محمد ان اكون اول من رد علي موضوعك الرائع وشكرا جزيلا وبارك الله لنا فيك
آخر مواضيعي 0 خااااااااص اشترى اى حاجه على النت ببلاش
0 ارجو من اخوانى اتاحة بنامج ال c للفرقة الاولى
م/عمرو السيد غير متواجد حالياً   رد مع اقتباس
قديم 02-12-2007, 11:40   #5
آخر مواضيعي 0 Oxford Guide to English Grammar
0 Guide to Electric Power Generation, Second Edition
0 Bmw Technical ************************ation
0 مكتبة كتب ومراجع هندسة السيارات
0 استطلاع
قديم 30-12-2007, 05:04   #6
alae_ms is on a distinguished road
شكرااااااااااااااااااااااااااااا
alae_ms غير متواجد حالياً   رد مع اقتباس
قديم 11-02-2008, 10:39   #7
قرناس is on a distinguished road
يعطيك الف عافية على هالبرنامج والله انو رهيب
قرناس غير متواجد حالياً   رد مع اقتباس
قديم 19-03-2008, 12:39   #8
سيد عبده is on a distinguished road
Thanxxxxxxxxxxxxxxxxxxxxxxxxxxx
سيد عبده غير متواجد حالياً   رد مع اقتباس
قديم 26-03-2008, 09:17   #9
شكرا ياهندسه
آخر مواضيعي 0 شرح برنامج inventor صوت وصوره
0 استفتاء علي افضل برامج التصميم
0 كورس تعليمي جديد لوحش التصميم solid works
0 تعليم سوليد ورك وانيفينتور &فيديو
0 موقع لتعليم برنامج ansys
التعديل الأخير تم بواسطة احمد الجزار2007 ; 26-03-2008 الساعة 09:21
قديم 28-03-2008, 08:54   #10
hamadam is on a distinguished road
hamadam غير متواجد حالياً   رد مع اقتباس
allinone, برامج, engineering, lotus, software, هندسية
Mechanical Engineering Software احمد الجزار2007 الهندسة الميكانيكية - Mechanical Engineering 65 08-06-2010 07:51
سبعة برامج هندسية مفيدة م/سامرغازى هندسة التبريد والتكييف 18 03-05-2009 06:44
برامج هندسية بسيطه ومفيدة newart الهندسة المدنية - Civil Engineering 12 18-04-2009 02:59
Software Engineering of Fault Tolerance Systems م/محمد لطفي كتب هندسة - Engineering books 0 03-05-2008 08:42
Software Engineering: A Practitioner's Approach م/محمد لطفي كتب هندسة - Engineering books 2 17-04-2008 02:02
الساعة الآن 05:42.
