| برامج هندسية - Engineering programmes البرامج الهندسية - برامج هندسة - اوتوكاد 2009 pspice archicad - electronic work bench - microsoft projec - staad matlab - mathcad -sap2000 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() تاريخ التسجيل: 09 2007
![]() Mathworks matlab r2007b DVD ![]() Mathworks matlab r2007b DVD l 3.3 GB environment for algorithm development, data visualization, data analysis, and numeric computation. Using MATLAB, you can solve technical computing problems faster than with traditional programming languages, such as C, C++, and Fortran. You can use matlab in a wide range of applications, including signal and image processing, communications, control design, test and measurement, financial modeling and analysis, and computational biology. Add-on toolboxes (collections of special-purpose matlab functions, available separately) extend the matlab environment to solve particular classes of problems in these application areas. MATLAB provides a number of features for ************************ing and sharing your work. You can integrate your matlab code with other languages and applications, and distribute your matlab algorithms and applications. R2007b includes Simulink 7, new features in MATLAB, two new products released since R2007a, and updates and bug fixes to 82 other products. Subscribers to mathworks Software Maintenance Service can download r2007b product updates. R2007b introduces a major new feature: C code generation from Embedded matlab functions directly at the matlab command line, using Real-Time Workshop. In addition, Embedded matlab Function blocks in Simulink support algorithms in multiple M-files. Download http://www.filefactory.com/file/b228c0/ المصدر: منتدى المهندس كوم كلية الهندسة |
![]() تاريخ التسجيل: 12 2007
جزاكم الله كل خير على هذه المجهودات، وإن شاء الله هي في ميزان حسناتك.
![]() تاريخ التسجيل: 01 2008
thanx sooooooooooo
![]() تاريخ التسجيل: 02 2008
بارك الله فيك
Thank you veeeeeeeeeeeeeery much
| dvd, mathworks, matlab, r2007b |
| برنامج Mathworks Matlab R2010a الشهير باخر اصدراتة | Avatar | برامج هندسية - Engineering programmes | 5 | 08-04-2012 04:18 |
| MatLAB Programming» | م/محمد لطفي | كتب هندسة - Engineering books | 3 | 24-07-2011 06:30 |
| مجموعة من***كتب***ال***************matlab | ahmed1234 | الهندسة الميكانيكية - Mechanical Engineering | 0 | 01-07-2010 04:57 |
| Mathworks Matlab R2008b DVD ISO Nov. 2008 | Newhak | الهندسة الميكانيكية - Mechanical Engineering | 2 | 10-05-2009 10:32 |
| Mathworks Matlab R2007b DVD | Newhak | برامج هندسية - Engineering programmes | 10 | 07-04-2008 10:54 |
