![]() تاريخ التسجيل: 09 2007
السلام عليكم ورحمه الله وبركاته Alcohol 120% enables you to make a duplicate back-up to recordable media of nearly all your expensive Game/Software/DVD titles, and/or an image that can be mounted and run from any one of Alcohol's virtual drives. No other software available enables you to create up to a staggering 31 virtual drives, allowing you to run your game images at over 200x faster than from a conventional CD-ROM. alcohol 120% is a powerful utility that uses a unique combination of options to ensure a perfect back-up every time. All you need is a PC combined with a CD or a DVD burner. No more replacing your expensive original discs due to loss, theft, scratches, or other media imperfections. Your duplicate works just like the original; your entire collection can be archived and your investment protected. *** In the home: Have you had experiences with the common conditions of CDs/DVDs? They can easily get scratched, damaged, broken, lost or even stolen. alcohol provides you with peace of mind and protects your investment. *** Your original games/program discs can be safely stored away. Alcohol-created images mean that you always have your expensive media stored safely on your hard drive for instant retrieval at the click of a button. No more searching for the correct game disc or software application install disc, everything is at your fingertips. *** You can now, for instance, simultaneously play your favourite game and bring up your route planner without having to eject and reload any physical discs, The 31 virtual drive ability of alcohol means you can have the equivalent of a staggering 31 CD-ROM drives in your Home PC, all instantly accessible. You can simply and quickly run your Disc image at around 200 times faster than that of a conventional CD-ROM drive. If you need a program or CD it is immediately there - always ready to use! *** At the office: Program discs and many other applications generally require the original disc to be in the computer's CD-ROM drive. This restricts the amount of people in your office who can have access to the same software at the same time without the cost of additional discs. Alcohol's virtual drives resolve that problem for you. No more hunting around the offices for that elusive disc you need to run your application, everything you require is just a click away. *** With alcohol you can store your CD images on your office server, your colleagues and employees at their respective networked workstations will never need to come asking for a CD again, they will not even require an expensive CD-ROM drive installed in their workstation PC! A simple click is all that is required for them to have full access to any disc image they require for their day to day work. Your valuable CDs can be safely kept under lock and key. *** Does your company have a promotional CD for it's customers? Original pressed discs are expensive, using the alcohol 120% writing engine you can copy the original to inexpensive blank discs for distribution to your customers and keep your overheads down. *** alcohol software offers unrivalled usage to people from all walks of life regardless of if you are a hardened game player, busy school teacher, salesman, IT manager, student etc. alcohol has a niche in all your everyday computer needs. Let alcohol help you to help yourselves and give you the peace of mind you deserve when it comes to expensive PC media. Supported OS: Windows NT 3.x, Windows NT 4.x, Windows 2000, Windows XP, Windows Vista Changes in version 1.9.7.6022, 2007-12-22: • NEW alcohol Xtra, Pre-mastering wizard • NEW Reading Engine, Speed Improved • NEW Writing engine, Speed Improved • NEW Data Type Setting options for DVD medium • NEW SPTD layer version 1.53 • NEW Increased memory buffer for x64 system, if you have more than 4GB RAM installed, the maximum buffer size could be set as 1GB. 32bit system, 3GB ore more RAM installed, you can set max buffer as 512MB • FIX Special ICH9 device drive incompatibility issues • FIX Missing volume name of discs after auto mount upon system restart • FIX Addressed some blacklisting problems • FIX Bugs reported by some users • UPDATE Help files • UPDATE language files • UPDATE Devsupp additional support for more drives • UPDATE Upgraded Starwind ISCSI function • UPDATE ISCSI controller in Vista, *************** mode is no longer required للتحميل http://rapidshare.com/files/78718937/Alcoho.rar المصدر: منتدى المهندس كوم كلية الهندسة |
![]() ![]() ![]() تاريخ التسجيل: 12 2007
مشكوووووووووووووووووور ويعطيك الف عافية
مشكوررررررررررررررررررررررررررررررررر
| 120%, 6022, alcohol, اخر, اصدار, برنامج, retail |
| برنامج Allpile v7.3B Full-Retail | volume | برامج هندسية - Engineering programmes | 1 | 14-12-2009 03:23 |
| حصريا برنامج 4pos pos retail 472 | المسلم | منتدى البرامج العام | 0 | 17-06-2009 03:26 |
| برنامج الكحول لنسخ الاسطوانات المحميه وعمل سواقه وهميه Alcohol 120% v.1.9.7.6022 | sangam | منتدى البرامج العام | 3 | 01-04-2009 12:55 |
| Alcohol 120% v1.9.7 Build 6022 | Mr Msae3 | منتدى البرامج العام | 0 | 29-03-2009 01:01 |
| Alcohol 120% 1.9.8.7117 عملاق النسخ الشهير وعمل اقراص وهمية اصدار جديد + العربية | Mr Msae3 | منتدى البرامج العام | 0 | 13-02-2009 10:05 |
