حصريا برنامج Keep Alive 3.0.12.1
قديم 31-03-2009, 10:01   #1
افتراضي حصريا برنامج Keep Alive 3.0.12.1
The Keep alive application was designed to be a network and server monitoring tool that can help you pro-actively tackle problems before your users start to complain!
If you run a website, look after a rack of database servers, or perhaps simply Keep an eye on your home PC from work, then Keep-Alive 2 is for you.
Keep-Alive 2 can monitor a device using an assortment of methods, so you'll still know if your mail server application has failed even if the server still responds to pings for instance.
Here are some key features of "Keep Alive":
The following monitor types are currently supported:
· Ping - returns roundtrip time.
· Web Server - including auth and SSL if required. Returns the page.
· Microsoft SQL Server - Connect to DB using SQL or Windows auth. Retuns connection state. Can run query and *************** based on no. rows returned.
· MySQL - Connects to a MySQL DB, can run query and *************** based on no. rows returned.
· SMTP Server - Returns server header. Supports SMTP Auth. Can send test mail.
· POP3 Server - Returns number and size of waiting messages
· FTP Server - Returns the home directory listing. Specify login or use anon. Option for PASV mode.
· Custom Port - Connects to a custom port number and returns response if any.
· Windows Services
The following *************** types are currently supported:
· Messages logged to Windows Event Log.
· Email ***************s to one or more recipients
· SMS ************ Message ***************s to one or more recipients using either a mobile device connected ******************ly to the computer, or a web-based SMS provider (3rd party account needed)
· System tray balloon warnings (if the console is running)
Reporting options:
· Two reports are currently provided - a simple statistics view for all monitors, and a more detailed one showing the failure times for monitors in a given date range.
· Problems with the service are logged to the Windows Event Log
Limitations:
· 30 days trial
آخر مواضيعي 0 حصريا برنامج eLecture Server 1.0
0 حصريا برنامج GPList 1.0
0 حصريا برنامج Kaspersky Anti-Virus Update April 05, 2009
0 حصريا برنامج ImTOO MPEG Encoder Ultimate 5.1.23.0402
0 حصريا برنامج Clicky Gone Portable 1.4.1.1
3.0.12.1, alive, برنامج, حصريا
برنامج Alive Video Converter 3.3.0.2 عاشق الرحمن منتدى البرامج العام 0 10-03-2010 10:35
حصريا برنامج Alive PSP Video Converter 1.8.2.8 المسلم منتدى البرامج العام 1 21-04-2009 10:12
حصريا برنامج Alive Zune Video Converter 1.9.0.9 المسلم منتدى البرامج العام 0 11-04-2009 10:48
حصريا برنامج Alive MP3 WAV Converter Standard 3.9.6.6 المسلم منتدى البرامج العام 0 11-04-2009 10:43
حصريا برنامج Alive MP4 Converter 2.0.8.8 المسلم منتدى البرامج العام 0 11-04-2009 10:38
الساعة الآن 11:55.
