VueScan is a scanning program that works with most high-quality flatbed and film scanners to produce scans that have excellent color fidelity and color balance.
VueScan is very easy to use, and also has advanced features for restoring faded colors, batch scanning and other features used by professional photographers. VueScan changes nothing on your system, installs nothing in your operating system and all other scanner software will continue to function. You can purchase VueScan at any time and instantly get a ****************** number that disables image watermarking. To upgrade VueScan, just install this trial version and enter your ****************** number to enable the Edition you've purchased. Use the About menu command in VueScan to display what Edition you have and whether you qualify for a free upgrade. You don't need to uninstall the old version before installing this new version - the old version will be overwritten. VueScan is limited by the number of supported devices. What's New in This Release: [ read full changelog ] · Added "Output | PDF compression" option · Fixed problem with duplex scans on some older Avision scanners · Increased performance when working with large, rotated scans · Added support for additional HP scanners · DeskJet F735 · LaserJet 4700 · LaserJet 9040 · LaserJet 9050 · LaserJet CM1312 · LaserJet CM1312n · LaserJet CM2320 · LaserJet CM2320f · LaserJet CM2320n · LaserJet CM8050 · LaserJet CM8060 · LaserJet M1120 · LaserJet M1120n · OfficeJet 5100 · Officejet A809 · Officejet A909a · Officejet A909g · Officejet A909n · Officejet J5500 · Officejet L7400 · PhotoSmart C309a · PhotoSmart C4340 · Fixed problem with Chinese (Traditional) on Mac OS X · Added support for two dialects of Portuguese (Portugal and Brazil) http://www.softpedia.com/screenshots/VueScan_1.png Download File المصدر: منتدى المهندس كوم كلية الهندسة |
| 8.5.09, برنامج, حصريا, vuescan |
| برنامج VueScan 8.5.20 | عاشق الرحمن | منتدى البرامج العام | 0 | 10-03-2010 10:25 |
| برنامج VueScan 8.6.00 لادارة اجهزه الاسكانر | Avatar | منتدى البرامج العام | 0 | 03-01-2010 06:00 |
| برنامج VueScan 8.5.18 برنامج ادارة اجهزة الناسخ الضوئى سكنر – سكانر | mrfahd2010 | منتدى البرامج العام | 0 | 08-07-2009 12:20 |
| برنامج VueScan 8.5.19 | الصياد الكبير | منتدى البرامج العام | 0 | 07-07-2009 03:35 |
| حصريا برنامج VueScan 8.5.09 | المسلم | منتدى البرامج العام | 0 | 02-04-2009 03:12 |
