حصريا برنامج Golden Records 1.40
قديم 11-04-2009, 07:17   #1
افتراضي حصريا برنامج Golden Records 1.40
Golden Records is a program that helps you to convert your old vinyl LP records, tapes or cassettes onto CD or to wav or mp3 files.
Golden Records is designed specifically with Records and cassettes in mind and has been developed to make the conversion process as easy and intuitive as possible. Just install the software and follow the step-by-step wizard.
Here are some key features of "Golden Records":
· Convert audio from vinyl LP Records and cassettes into CD or Wave/MP3 format.
· Comes with a full set of audio restoration tools to clean up damaged audio.
· Simple wizard utility to walk you through the conversion process.
· Includes full feature CD-Burner.
· Encodes into mp3 or wave files with the ability to add mp3 ID tags to converted files.
· Automatically normalizes recordings.
· Automatically applies dc offset correction recordings.
· Click / pop elimination when recording from vinyl records.
· Automatic hiss and noise reduction.
· Automatic 'phono' RIAA eq correction (if your old record player does not have a preamplifier).
· Can convert 78 Records playing on a RPM player.
Requirements:
· About 600MB hard drive space for every album you want to convert.
· A CD burner drive if you want to burn the audio to CD.
· A sound card.
· A record player capable of playing 33 or 45 RPM Records (for converting from LP).
· Cassette Deck with Amplifier (for converting from cassette tapes).
آخر مواضيعي 0 حصريا برنامج novaPDF Standard Desktop 6.2 Build 295
0 حصريا برنامج Winzoom 2.1
0 حصريا برنامج InTask Personal 1.47.0
0 حصريا برنامج Norton AntiVirus Virus Definitions April 13, 2009
0 حصريا برنامج CPU Load in Tray 1.3a
1.40, 140, برنامج, golden, حصريا, records
برنامج Golden filter لحجب المواقع الاباحيه فقط على المهندس كوم zarzor منتدى البرامج العام 0 05-02-2011 05:40
برنامج Golden Software Grapher 8.0.278 Avatar برامج هندسية - Engineering programmes 0 05-01-2010 04:41
برنامج Golden Software Surfer v9.8.669 volume برامج هندسية - Engineering programmes 0 26-12-2009 02:22
حصريا فلتر الأمان ( أفضل برنامج للحماية من المواقع الإباحية ) Golden Filter Pro Hamada Bader منتدى البرامج العام 0 30-08-2009 03:47
حصريا برنامج Golden Records 1.40 المسلم منتدى البرامج العام 0 11-04-2009 04:17
الساعة الآن 01:00.
