Xilisoft MP3 WAV Converter, an exclusive MP3 and WAV encoder, can convert MP4, M4A, MP2, WAV, MP3, WMA, OGG, AAC, FLAC, APE, VQF etc. to the most popular audio formats MP3, WAV and MP2.
The software is also able to extract audio tracks from video formats like AVI, MPEG, WMV and ASF and save them as MP3, MP2 or WAV format. Supports copy ID3 tag between formats, so that you can easily transfer all of the most useful tag fields from one format to another. xilisoft MP3 WAV converter supports batch conversion. With xilisoft MP3 WAV converter you can convert and encode MP3 and WAV and extract audio tracks from video formats. The output quality is adjustable. When converting to MP3, bitrate, VBR or CBR, stereo or mono are selectable; and when converting to WAV, sample rate, stereo or mono and compression method are selectable. Users are able to edit the output path or use the same one as the input path. xilisoft MP3 WAV converter allows users to select whether delete the original files. Here are some key features of "Xilisoft MP3 WAV Converter": · Convert WAV, WMA, OGG, AAC, FLAC, APE, VQF to MP3; · Convert MP3, WMA, OGG, AAC, FLAC, APE, VQF to WAV; · Support batch conversion; · Copy ID3 tag between audio formats ( reserve ID3 tag during conversion); · When converting to MP3, bitrate, VBR or CBR, stereo or mono are selectable; · When converting to WAV, sample rate, stereo or mono and compression method are selectable; · Users are able to edit the output path or use the same one as the input path; · Allow users to select whether delete the original files Requirements: · Intel Pentium II 350MHz or above, or any Athlon ![]() Download File المصدر: منتدى المهندس كوم كلية الهندسة |
| 0402, 2.1.76.0402, converter, برنامج, حصريا, mp3, wav, xilisoft |
| حصريا برنامج ImTOO MPEG to DVD Converter 3.0.42.0402 | المسلم | منتدى البرامج العام | 1 | 01-05-2009 11:36 |
| حصريا برنامج Xilisoft Zune Converter Suite 5.1.23.0402 | المسلم | منتدى البرامج العام | 0 | 15-04-2009 03:34 |
| حصريا برنامج Xilisoft Zune Converter Suite 5.1.23.0402 | المسلم | منتدى البرامج العام | 0 | 14-04-2009 05:20 |
| حصريا برنامج Xilisoft Audio Converter 2.1.76.0402 | المسلم | منتدى البرامج العام | 0 | 14-04-2009 04:18 |
| حصريا برنامج Xilisoft AVI to DVD Converter 3.0.42.0402 | المسلم | منتدى البرامج العام | 0 | 02-04-2009 11:20 |
