The prevx CSI - free malware Scanner is a fast effective scanning and real-time checking against the most comprehensive malware database in the world.
Prevx CSI is click-and-go and requires no installation or reboot, which makes it quick and easy to use. Its small size allows you to take it anywhere,you have the possibility to use it as many times as you like and even copy or send it to your friends. Prevx CSI allows you to benefit from the knowledge gained from the entire prevx community. Are you responsible for your company's security? prevx CSI for Business can be used free of charge in low volume (up to 250 PCs) by business users and large enterprises, subject to a simple registration process. Prevx CSI for Business may also be configured to run in silent mode allowing companies to deploy it easily using a simple login ******************. Business users also benefit from a web based console which provides a summary view of all PCs scanned by prevx CSI with clear details of which ones are infected. Download File المصدر: منتدى المهندس كوم كلية الهندسة |
| 3.0.1.56, csi, برنامج, free, حصريا, malware, prevx, scanner |
| Ad-Aware Free Anti-Malware 8.1.2 | لا تنسى ذكرالله | منتدى البرامج العام | 0 | 21-12-2009 10:18 |
| حصريا برنامج Vnd Hard Disk Scanner And Registry Scanner 5.6.1 | المسلم | منتدى البرامج العام | 0 | 18-06-2009 06:58 |
| حصريا برنامج SoftPerfect Network Scanner 4.2.0 | المسلم | منتدى البرامج العام | 0 | 14-06-2009 10:40 |
| حصريا برنامج Angry IP Scanner 3.0 Beta 4 | المسلم | منتدى البرامج العام | 0 | 25-03-2009 09:38 |
| حصريا برنامج SoftPerfect Network Scanner 3.9 Build 191 | المسلم | منتدى البرامج العام | 0 | 24-03-2009 02:16 |
