23-09-2009, 09:02
#1
Registry Mechanic 8.0.0.907 فى احدث اصدار
برنامج Registry mechanic البرنامج الشهير من شركة pctools لاصلاح وتنظيف المفاتيح التالفه في الريجستري لاداء افضل واسرع للكمبيوتر والبرامج والتصفح للانترنت كما يقوم باصلاح الاخطاء في الريجستري
23/9/2009
Registry mechanic is an advanced Registry cleaner for Windows® that can safely clean, repair and optimize your Registry in a few simple mouse clicks! With Registry mechanic you can safely clean, repair and optimize the Windows® Registry with a few simple mouse clicks! Problems with the Windows® Registry are a common cause of Windows® crashes, slow performance and error messages. By using a Registry cleaner regularly and fixing Registry errors your system should not only be more stable but it will also help improve your system performance without expensive hardware upgrades. Learn more about the importance of a clean Registry with our Registry insight. With a few easy steps Registry mechanic will scan your entire Registry for any invalid entries and provides a list of the Registry errors found, you can then choose to selectively clean each item or automatically repair them all.
For your convenience and protection Registry mechanic can also make a backup of any repairs made so that you can easily recover any changes if required.
Registry mechanic uses a high-performance detection algorithm to quickly identify missing and invalid references in your Windows registry. These problems can occur for many reasons including being left-behind after the un-installation or incorrect removal of software, by missing or corrupt hardware drivers, or orphaned startup programs.
