![]() تاريخ التسجيل: 07 2008
تم شكره 3 مرة في 2 مشاركة
Suzuki Worldwide 03.2009 | RapidShare | RAR 1.74 Gb Electronic catalog to search for parts Suzuki World Wide provides information on spare parts - spare parts numbers, pictures, history substitution rates, etc. all automobiles of firm Suzuki. Year: 2009 Size: 1.74 GB Version: 2.4.1 from 03/2009 Compatibility with Vista: unknown Language: English Tabletka: Present Supplied parts catalog Suzuki Worldwide on one DVD disc, supports parts catalog Suzuki multiple languages. Parts Catalog Suzuki EPC works with the VIN-code (sort parts suitable only entered WIN-y) or on models of Suzuki, a tran****************** of each position VIN (Optional Code), search by number, name of parts, etc. , Also appeared to copy numbers of parts and VIN to the clipboard. Extras. Information: Installation. Carefully read! 1. Burn a disc from an image, or simply connect its image (with NTI, NERO or Alcohol) 2. It is advisable to close all unnecessary applications 3. Prepare for the fact that your PC will be installed ************ (jre 1.4.1) and. NET FrameWork 1.1 4. Install the program by running setup.exe from the disk and follow the instructions. 5. Unpack the archive containing a license generator (say, on the desktop. After the successful completion of this operation can be erased). 6. The catalog generator (******************_ProQuest) c using the "notepad" to open the file 1.dat. 7. Replacing the value FEATURE c AUCYPURRRdh (or any other) on AUSZPWRRRbb. If a directory with key generator already has a file "lic_all.lic", delete it. 8. Run file Run.bat 9. In the newly obtained license file "lic_all.lic" using "notepad" remove formatting strings, string form FEATURE AUSZPWRRRbb bhepcls 1.0 14-feb-2020 0 DD76051C04603488E3EB \ HOSTID = ANY converted into a string FEATURE AUSZPWRRRbb bhepcls 1.0 14-feb-2012 0 DD76051C04603488E3EB HOSTID = ANY 10. Add contents of the file lic_all.lic the end of the file \ Program Files \ BHPS \ lic \ lic \ lic_all.lic and \ Program Files \ BHPS \ lic \ lic \ lic_any.lic, expanding existing lines there, example: SERVER station-main ANY 27009 DAEMON bhepcls FEATURE AUSZPWRRRbb bhepcls 1.0 14-feb-2012 0 DD76051C04603488E3EB HOSTID = ANY 11. Start ProQuest Product Licenser 12. Make sure the installed licenses. 13. Close ProQuest Product Licenser 14. Start the Suzuki Worldwide automotive [IMG][/IMG] المصدر: منتدى المهندس كوم كلية الهندسة التعديل الأخير تم بواسطة fss911 ; 15-12-2009 الساعة 11:49 |
| 03.2009, برنامج, suzuki, worldwide |
| سوزوكي كاري suzuki carry | عارف 7 | قسم اجهزة تشخيص الاعطال | 3 | 19-02-2011 11:17 |
| برنامج Windows Live Messenger 2009 2009 Build 14.0.8089.726 برنامج محادثات فورية ومشا | bondoa2 | منتدى البرامج العام | 0 | 03-09-2009 02:00 |
| SUZUKI Esteem | BMW M5 | هندسة السيارات - Automotive Engineering | 0 | 01-09-2009 10:03 |
| برنامج Smarty Uninstaller 2009 Pro v2.5.1 برنامج حذف البرامج والملفات التالفة من الجه | moamen0010 | منتدى البرامج العام | 0 | 03-08-2009 01:43 |
| اخيراا:اقوي واشهر برنامج مكافح الفيروسات Norton AntiVirus 2009 2009 16.5.0.135 | NIGA | منتدى البرامج العام | 1 | 05-04-2009 11:39 |
