Machete 3.5 Build 11
قديم 21-12-2009, 01:46   #1
ayat is on a distinguished road
افتراضي Machete 3.5 Build 11
Machete Build
برنامج machete 3.4 build 44 (Trial) رنامج تحرير الفيديو الشهير 2010 برامج تحرير الفيديو تقطيع الفيديو و دمج الفيديو والكتابة على مقاطع الفيديو وعمل فيديو بلوتوث للجوال وللاجهزة المحمولة وغيرها حمله من جي سوفت
هذه تغذية نظيفة من موقع سوفت بيديا نطمع بان تفيدكم
خلاصات تغذية من قسم Video Editors ببرامج تحرير وتقطيع ودمج ودبلجه مقاطع الفيديو ايضاً يمكنك الحصول على نسخ اكثر من على جي سوفت
Machete is a quick and lean video editor. It is an ideal solution for easy and quick "slicing" of your video files: you can delete unnecessary fragments (e.g. cut out commercials), copy, move, mix and save individual pieces.
This means that machete combines functionality of both video splitter (cutter, trimmer) and video joiner (for joining video files with the exactly the same formats) and more. Additional functions available: ability to save video and audio streams as separate files, ability to add/replace audio stream in AVI, WMV and FLV files and ability to save a video frame as a bitmap (.bmp) file.
At this moment, machete is able to edit ASF, AVI, WMV, WMA, FLV and MP3 files. Most video and audio codecs are supported: DV, DivX, XviD, H.264 (AVC), WMV, MSS, WMA, MP3, AC3, AAC and other). Support for more video formats will be added in future versions. The program's key feature is that editing of a video file is performed without re-encoding (so-called lossless editing).
This not only saves time, but also prevents loss of video or audio quality. Also, it means that you would not need powerful and expensive computer to edit your video material. After a file is edited and saved, it retains its original format.
The program does not require installation of any special codecs for multimedia editing in addition to regular decoders that are needed for video viewing and audio playback. You don't need any special skills or advanced knowledge to edit video with Machete.
آخر مواضيعي 0 ProgDVB 6.25 / 4.92.4
0 new filetypes part 1
0 Able Batch Converter 3.3.12.7
0 Atrise Lutcurve 1.4.4
0 ODF Add-in for Microsoft Word 3.0
ayat غير متواجد حالياً   رد مع اقتباس
build, machete
حصريا برنامج cFosSpeed 4.53 Build 1521 Beta / 4.52 Build 1509 المسلم منتدى البرامج العام 0 17-06-2009 04:19
حصيا برنامج Free*************** 4.0 Build 1711 Beta / 3.92 Build 1644 M_M منتدى البرامج العام 1 03-04-2009 03:59
حصريا برنامج cFosSpeed 4.51 Build 1496 Beta / 4.50 Build 1458 المسلم منتدى البرامج العام 0 02-04-2009 01:05
حصريا برنامج cFosSpeed 4.51 Build 1493 Beta / 4.50 Build 1458 المسلم منتدى البرامج العام 0 26-03-2009 04:48
حصريا برنامج cFosSpeed 4.51 Build 1492 Beta / 4.50 Build 1458 المسلم منتدى البرامج العام 0 25-03-2009 07:52
الساعة الآن 05:05.
