| قسم اجهزة تشخيص الاعطال اجهزة تشخيص الاعطال |
![]() تاريخ التسجيل: 12 2007
![]() جهاز تشخيص الاعطال star diagnosis الجهاز المتخصص لفحص المرسيدس بكل انواعها ويقوم بفتح السرعة وتعريب الشاشات والبرمجة المطلوبة من ارب وغيرها Product De******************ion PC Based Mercedes-Benz Diagnostic System WO/Laptop Compact 3- star diagnosis Tester for Benz (DAS+WIS+EPC) - Compact star 3 is the professional diagnostic equipment for Mercedes Benz cars manufactured after year 2000, it is the replacement of HHT. Compact 3--Star operate based on the Windows XP system, it includes workshops information system(WIS system), the movement management system (STARUTILITIES) and the automatically diagnose system (the DAS system) Introduction MB star realizes all the functions of official factory Benz Star2000: Reading out and erasing trouble code; Reading the real-time data of sensor and actuator; Coding and programming. It applies the latest high-tech central gateway system of car model 221/211 and 203 with software version updated to January of 2008, can enter all the Benz cars, such as autobus truck, saloon car, sports car, smart car and so on. Configuration - MULTIPLEXER - 16+PIN OBD II cable - 38+PIN cable - 14+PIN cable - 4+ pin cable - RS232 communication cable (navigation port) Optional Configuration: 1. IBM laptop: Such as 600E, T20, T21, T22, T23, T30...With COM. - Testable system - ENGINE - AUTO-SPEED - AIR CONDITIONAL SYSTEM - SRS - ABS - ASR - MPL - GM - Benz ORIGINAL ANTI-THEFT DASX SYSTEM - KEYLESS ENTERING SYSTEM- OBD-II SYSTEM...Other new system, 100% as same as original diagnostic star 2000. FUNCTION: Reading trouble code Erasing trouble code Live-data, adaptation Component testing Maintenance information consultation Component location diagram Wiring diagram. Coding the new ECU... DAS: Concise interface and straightforward operation with IBM high-quality computer can realize the quick and accurate code reading and the whole car system testing. WIS net: Supply the whole view of the wiring diagram in a car, component location diagram and maintenance method. What you do is to enter the chassis number, and then you will get the manufacture data, engine configuration and the car model -----all in detail. Star finder: Component location diagram for colorized. Software: It is 08, 2008, more than 20 kinds of language, such as, en, de, fr, cn, jp, kr, gr, br, pl, dk, ru, RO, PT, se, tr, es, hu, sp, it YouTube - Mercedes-Benz Dealership Scan Tool (Star Diagnosis) المصدر: منتدى المهندس كوم كلية الهندسة |
![]() تاريخ التسجيل: 03 2010
اخي الكريم ممكن اعرف كيف احصل على البرنامج والكبلات الرجاء المراسلة على الاميل
![]() ![]() تاريخ التسجيل: 10 2007
تم شكره 12 مرة في 10 مشاركة
ان شاء الله تجد من يساعدك
التعديل الأخير تم بواسطة المهندس/حماده ; 09-03-2010 الساعة 08:31 |
![]() ![]() ![]() تاريخ التسجيل: 12 2009
تم شكره 9 مرة في 9 مشاركة
للتواصل مع الاداره من هنا منتدى المهندس كوم كلية الهندسة - الاتصال بنا
الاخ طنطاوي
ارجو مراسلتي للاهميه بخصوص الجهاز وترك رقم هاتفك للاتصال بك التعديل الأخير تم بواسطة المهندس/حماده ; 09-03-2010 الساعة 07:33 |
نرجوا التقيد بالشروط لا يسمح بوضع روابط لمواقع اخرى او ايملات او ارقوام هواتف وتستطيع التواصيل مع الاداره وهما سيدلوك على المفيد
التعديل الأخير تم بواسطة المهندس/حماده ; 09-03-2010 الساعة 07:35 |
![]() ![]() ![]() ![]() تاريخ التسجيل: 11 2006
تم شكره 18 مرة في 10 مشاركة
تم الرد على اميلك
![]() تاريخ التسجيل: 10 2008
هل أستطيع تثبيت star diagnosis في أي جهاز كمبيوتر
| الأعضاء الذين قالوا شكراً لـ belghiti على المشاركة المفيدة: | محمد مصطفي سيد محمد (02-07-2011) |
aslam sorry to all my computer now I can write english only
there are mb star c3 working with any computer and another mb star working with IBM or DELL and should your laptop has comport 9pin in back |
| الاعطال, diagnosis, تشخيص, جهاز, star |
| الذين يشاهدون محتوى الموضوع الآن : 2 ( الأعضاء 0 والزوار 2) | |
| جهاز تشخيص الاعطال AutoBOSS V30 | طنطاوى | قسم اجهزة تشخيص الاعطال | 112 | 19-01-2012 12:49 |
| جهاز تشخيص الاعطال LAUNCH X431 Master | طنطاوى | هندسة السيارات - Automotive Engineering | 6 | 12-07-2011 12:03 |
| جهاز تشخيص الاعطال jbt-cs 538d | طنطاوى | هندسة السيارات - Automotive Engineering | 3 | 08-11-2010 01:17 |
| جهاز تشخيص الاعطال Toyota - Intelligent Tester II | طنطاوى | هندسة السيارات - Automotive Engineering | 2 | 16-05-2010 05:06 |
| كل سنة وانت طيبين عايز اتعلم عاى جهاز تشخيص الاعطال | tiger1985kera | هندسة السيارات - Automotive Engineering | 23 | 26-04-2010 01:34 |
