Mechanical Engineering Software
قديم 12-04-2008, 01:03   #1
Thumbs up Mechanical Engineering Software
[CENTER]
[B][img]http://www5.***************************/2008/04/01/21/508265884.gif[/img]
Steam Tables
Steam Properties
This program calculates the properties of superheated, saturated, or wet steam. In addition it calculates the properties of
saturated water.
Steam Tables
(Metric and US units) This program provides the thermodynamic properties of water using IFC formulation for industrial use.
Knowing any two properties, the user is able to completely define the properties of water/steam. Unlike most steam table
programs, this program also provides the user with the point's location on the T-S diagram. Multiple points can be connected by a
line, defining the user's process system. It even gives you the steam quality
http://www.engineering-software.com/...s/steademo.exe
TriMAX
Tri MAX™ is a powerful software resource for the practicing engineer, chemist, or student. It is your best source of data. Through
the use of menus: data and functionality are put at the finger tips of the power user. Tri MAX™ provides data such as periodic
table, steam tables, heat capacities, critical values, viscosities, diffusion coefficients, thermal conductivities. Math functions are
also provided, such as linear regression, quadratic equation, curve fitting, and a calculator that goes far beyond the standard
calculators available for Microsoft™ Platforms.
http://www.engineering-software.com/...30.findrex.zip
Steam Approximations
Engineering software has developed a new Windows based software package, Steam Approximations, that quickly, easily and
reliably calculates thermodynamic and transport properties of steam for both saturated and superheated areas.
This software package should prove to be a good tool for those who are involved at various levels with design, operation and
management of energy conversion systems. It should provide the user with the opportunity to more quickly, easily and effectively
do his/her work, explore more options, save time and give more confidence in carrying out engineering calculations.
http://www.engineering-software.com/...gware32-7d.exe
Piping and Fluid flow
Mechanical Toolbox
(US units only) This program contains several functions commonly used by mechanical engineers. These functions include a pipe
database, flange dimensions, pressure/temperature ratings, hardness conversions, wire gage dimensions, minimum pipe wall
calculator, units conversion, stress intensity factors (SIFs) and a pressure drop calculator
http://www.engineering-software.com/prDemos/mtbdemo.exe
Piping Pressure Loss
This program calculates the pressure loss of fluids flowing under pressure in circular pipes. The program can calculate flow in
either compressible mode (for gases) or incompressible flow. It allows a choice of units: gpm, pph, scfm, or acfm. Any single-
phase liquid or gas can be accepted. The properties of water, steam and air are built in
http://www.cuservices.net/DemoDownloads/PlossDemo.exe
Pipe Network (Hardy Cross)
This program uses the iterative Hardy-Cross algorithm to determine the flow and pressure loss in each leg of a series-parallel pipe
network.
http://www.cuservices.net/DemoDownlo...etworkDemo.exe
P-Drop
P-DROP quickly and easily calculates air pressure drop in duct systems that have been sized using a ductulator. The software also
calculates water pressure drop for systems sized by charts.
These pressure drops can be used to select fans and pumps more accurately
Psychrometrics
Psychrometrics
(Metric and US units) This program provides Psychrometric properties of air given two properties as input values at a known
altitude (or atmospheric pressure). The properties are determined using the ideal gas law for the behavior of air. Once the
properties are determined, the point is indicated on the Psychrometric chart. Process lines can be connected between any two
know points, this will provide the user with the differences in moving from one point to the next. Additionally, this program will
allow the user to perform some basic HVAC calculations that depend on psychrometrics
http://www.engineering-software.com/...s/psycdemo.exe
Psychrometrics
This program calculates the properties of a mixture of air and water vapor such as used in HVAC applications. In addition, the
porgram calculates the results of the four most common types of heating and cooling psychrometrics processes
http://www.cuservices.net/DemoDownloads/PsychDemo.exe
Heat Transfer
PHEdesign1.0
PHEdesign1.0 program for simulations of the plate heat exchanger. By setting our controlled variables and material properties, the
optimum plate dimensions and materials can be selected by the computer program. These are included rate of heat transfer, the
size of plate heat exchanger, and chevron angle (beta) between 25 to 65 degrees under single pass condition. Also this program is
capable of calculating the pressure drop in plate, from which the energy and material can be saved by decreasing the pressure
drop (decreasing horsepower per unit area) and increasing chevron angle.
http://www.engineering-software.com/.../PHE_trial.exe
Space Heating Load
This program calculates the maximum heating load required in a space (single zone) so that a furnace can be sized. Heat transfer
coefficients are built in for many types of wall, floors, doors, windows, etc. Custom values can also be used. The heat needed for
infiltration & humidity control are also calculated. Final furnace sizes are tabulated with several values of efficiency.
Surface Condenser
This program, for analysis of turbine steam condensers, can either calculate the performance of a known condenser, or can
calculate the design requirements of a new condenser for a known steam load. The steam and condensate properties are built in.
Also a complete range of tube properties are built in. The cleanliness of a given condenser can be etermined quickly using a trial
and error method.
http://www.cuservices.net/DemoDownlo...denserDemo.exe
Cooling Tower
Cooling Tower Analysis is a powerful, user friendly, program for the analysis of induced, mechanical-draft, counterflow cooling
towers. The program can be used for the analysis of existing towers or for the preparation of specifications for new towers.
http://www.cuservices.net/DemoDownloads/TowerDemo.exe
Steam Heater
This program calculates the performance of a steam, ************l-and-tube heat exchanger of known construction using rigorous
formulations. Steam and water properties are built in. The type of fouling can be specified. The ************l-side fluid is always steam.
The tube side fluid can be any non-condensing fluid.
Heat Recovery Steam Generator
This program calculates the amount of steam that can be generated by a fired or unfired waste heat boiler (Heat Recovery Steam
Generator). The steam and condensate properties are built in. The program first calculates a design mode and then an "off-
performance mode" for changed conditions. Note: the purpose of this progam is to predict the amount of steam that can be
generated from a waste heat source. The program does not calculate the square feet of each section of the HRSG. Instead it
calculates the value of U x A.
Insulation Economics
This program calculates the heat loss and surface temperature of an insulated pipe of specified diameter and internal
temperature. It then calculates the present worth cost, $/foot, to own and operate each insulated system. This allows the user to
select the optimum insulation thickness for each pipe based either on the cost of the insulation and heat loss or on the maximum
acceptable surface temperature. Four types of insulation are supported. Pipe sizes through 36" are included. Three layers of
insulation are supported ranging in thickness from 0 to 10".
http://www.cuservices.net/DemoDownloads/InsulDemo.exe
************l & Tube Heat Exchanger
Heat Exchanger Performance is a powerful, user friendly, program for the analysis of two types of Heat Exchangers: ************l & Multi-
Tube Exchangers, and Double Pipe Exchangers. In either case, the tubes are of the bare-tube type. The program will analyze the
performance of a known heat exchanger: Given the flows and inlet temperatures of the Tube-side fluid and the ************l-side fluid, the
program will predict the exit temperatures of both fluids and the total heat exchanged
http://www.cuservices.net/DemoDownloads/HxgrDemo.exe
آخر مواضيعي 0 تعليم سوليد ورك وانيفينتور &فيديو
0 تعليم اوتوكاد 2006 وبالعربي
0 LabVIEW v 8.5 برنامج القياسات
0 مفاجأه كبيييييييره جدااا solidworks v2009 علي الرابيد شير
0 over view about FLUENT
قديم 12-04-2008, 01:05   #2
Thumbs up
SIZE="4"]CAD[/SIZE]
Plane2002 Standard Edition
The purpose of this program is to save the time and relieve the difficulty of Funnel, sheet, or any kind of plate material design. This
must be bending to get a special shape of an angle form. Make it easy to calculate all real dimension or bending angles which get a
lot of time using many formularies to find out the result
http://www.engineering-software.com/...oPlane2002.zip
Plane2002 Professional Edition
Add Plane 2002 geometry capability to your application. Plane2002 is an ActiveX component that has been designed to help
engineers who use to design Funnels, Formed sheets, diffusers, or any kind of plate construction works within the following fields;
Air Condition manufacturing, Ventilation tunnels, Weighing and Packing equipment’s, Hydraulic and Air dynamic construction
Kader Frame 2.0
KaderFrame 2.0 solves plane frames and continuous beams. It calculates the normal forces, shearing forces, and bending
moments, draws and prints their diagrams. It also draws and prints the deformation shape. ************ files of most calculated data are
created on the same directory of the program. The program designs the sections by utimate strength method and draw the frame
and its sections to AutoCad 2000 or 2002 file. The user can modify the design sections before and of course after drawing to
AutoCad file. Only Metric system is used in this version.
http://www.engineering-software.com/...etupKFV20D.exe
KaderFrame
KaderFrame solves plane frames and continuous beams. It calculates the normal forces, shearing forces, and bending moments,
draws and prints their diagrams. It also draws and prints the deformation shape. ************ files of most calculated data are created on
the same directory of the program. The program designs the sections and draw the frame and its sections to AutoCad 2000 file.
The user can modify the design sections before and of course after drawing to AutoCad file. Only Metric system is used in this
version.
http://www.engineering-software.com/...etupKFV12D.exe
Mechanical Design
The EngineersToolbox (ETBX)
The EngineersToolbox (ETBX) is an advanced software package for engineering design, analysis, and reference. The current
version of ETBX covers a comprehensive range of engineering specialties, including solid mechanics, dynamics and controls,
fatigue and fracture mechanics, numerical methods, and engineering reference utilities. ETBX combines fundamental equations
with powerful computation and visualization capabilities in a computer-aided engineering environment.
EngiLab Beam!2D
EngiLab Beam!2D™ is an easy-to-use yet powerful engineering tool for the linear static analysis of plane (2D) frames for Windows.
It features a Full GUI (Graphical User Interface) for pre-processing or post-processing and uses the Finite Element Method (FEM) for
plane frames for its analysis purposes.
http://www.engineering-software.com/prDemos/Beam2D.zip
EngiLab Rod!2D
EngiLab Rod!2D™ is a powerful engineering tool for the linear static analysis of plane (2D) trusses for Windows, using a 2-Degrees
of Freedom per node approach. It features a Full GUI (Graphical User Interface) for pre-processing or post-processing and uses the
Finite Element Method (FEM) for plane trusses for its analysis needs
http://www.engineering-software.com/prDemos/rod2d.zip
Strake
Strake is a stand-alone program used to design the layout of Helical Strakes. The software also provides a reference picture for
forming and bending the strakes
http://www.engineering-software.com/...akeInstall.exe
WinThread
(US units only) This neat little program provides a large database for all types of bolts and screws. It also will tell you the required
torque.
http://www.engineering-software.com/...s/wthddemo.exe
WinPlate
(Metric and US units) Need a moment, reaction, stress or deflection on a circular plate? Then you need this program
http://www.engineering-software.com/...s/wplademo.exe
MechanicalPak
Get more power for your dollar and turn your calculating minutes into seconds with these 30 ready to run mechanical design Excel
calculation spreadsheets.
http://www.engineering-software.com/...chPakSetup.exe
آخر مواضيعي 0 هل تعلم لماذا (التفاح) حرام!!!!!!!!!!!!!!!!!!
0 لاول مره علي المنتيدات تعليم cosmos work عربي
0 fluent6.4
0 موقع لتعليم برنامج ansys
قديم 12-04-2008, 01:07   #3
Thumbs up
Stacks and Vessels
Stackdes (Self Supported Module)
STACKDES (Self Supported) is a stand-alone executable program that performs the overall structural analysis of Self Supported
Steel Stacks. It uses a stiffness matrix to completely model the stack and it's loadings, and then applies the appropriate
acceptance criteria based upon the user selected design code. The program also calculates the natural frequency of the structure
so that the dynamic along wind and dynamic across wind (vortex) loads can be applied to the stack. The software includes many
industry recognized codes and standards.
Stackdes includes an integrated version of Cone, Baseplate, and Strucflg. That means the user can automatically design these
components directly within Stackdes.
A security key is shipped with each order, by default a USB security key will be shipped. We also offer a Parallel security key. If you
prefer a Parallel security key please specify in the Comment Section of the order page. The security key will allow the user to
operate the software. The installation of the software can be installed on multiple computers, but will be limited by the number of
licenses purchased. At the end of the lease period, the software will revert to the demo mode
http://www.engineering-software.com/...desInstall.exe
BasePlate
(English Units Only) This program simplifies the design and analysis of a base plates vessels or stack. The program can
accommodate a single base plate or an anchor bolt chair. For base plates it can handle no gussets, one gusset per bolt, or two
gussets per bolt. The program handles anchor chairs with segmented top plates, or continuous top plates with one or two gussets
per bolt. Design of the plates, gussets, and local stress for the ************l is performed
http://www.engineering-software.com/...599.BPDemo.exe
Strucflg
(Metric & English Units) Have you ever had to design a plate flange for structural loads? Some examples of applications include
derrick leg flanges, monopole flanges, and stack body flanges. These types of flanges are often difficult to design because there is
not a commonly accepted procedure for the design of these types of flanges. STRUCFLG handles structural flanges either with or
without gusset plates. The program also considers the preload that should be placed on the bolt in order to keep the joint in
compression. Designing plate flanges has finally become very easy
http://www.engineering-software.com/...0.SFlgDemo.exe
MECAWind02
Calculates wind pressures per ASCE 7-02 "Minimum Design Loads for Buildings and Other Structures" for all types of buildings
and structures. Performs Gust calculations for Rigid and flexible structures, with the gust factor for flexible structures based upon
the natural frequency and damping of the structure. Also calculates the topographic factors and provides a comprehensive list of
all shape factors for the structure and attachments.
MECAWind02 will handle babled, monoslope, hipped, multspan gabled, sawtooth, and stepped roofs.
Different wind directions can be changed easily by re-entering the width and depth of the structure relative to the wind. All force
coefficients are calculated for windward walls, leeward walls, side walls, roof's perpendicular to ridge, roof's parallel to ridge, and
roof overhangs. MECAWind02 also calculates the force coefficients and wind pressures for Components and Cladding, simply by
entering the width, span, and zone for the component.
http://www.engineering-software.com/...indInstall.exe
MECAWind05
Calculates wind pressures per ASCE 7-05 "Minimum Design Loads for Buildings and Other Structures" for All types of buildings
MECAWind05 will handle low rise (<= 60 ft) buildings, using either the detailed (Method 2) or the simplified (Method 1) provisions.
MECAWind05 can also be used to calculate wind loads on buildings greater than 60 ft in height.
آخر مواضيعي 0 إعادة تحميل برنامج fluent 6.3 بعد انتهاء الروابط القديمه
0 برنامج لحساب معامل الأحتكاك في المواسير والأنابيب
0 برنامج HETaC Hydraulic Animated Training
قديم 12-04-2008, 01:08   #4
Saddle
(Metric & English Units) Perform analysis of a horizontal vessel supported on two saddles. The program performs a complete
analysis of the vessels based upon L. P. Zick's analysis procedure. The program allows the user to specify the wind load, thermal
loads, liquid load, and seismic loads on the vessel. A complete analysis is also performed on the saddle, calculating stresses on
bolts, base plate, web, stiffeners, and wear plate.
http://www.engineering-software.com/prDemos/SadDemo.pdf
Rotating Equipment
Steam Turbine
This program calculates the performance of a steam turbine section given the inlet steam temperature, pressure, flow and the
exit pressure. The program can also estimate the theoretical efficiency of a turbine section. The theoretical steam rate, exit
moisture, and enthaplies of the inlet and outlet streams are calculated. The steam tables are built in
http://www.cuservices.net/DemoDownlo...amTurbDemo.exe
Centrifugal Pump
This program calculates the suction head, discharge head, power required, Net Positive Suction Head (NPSH) & suction specific
speed for centrifugal pumps.
http://www.cuservices.net/DemoDownloads/pumpdemo.exe
Gas Compressor
This program computes the power required to compress any gas, the temperature required and the cooling required. As a side
calculation, the program calculates the molecular weight of any gas mixture
http://www.cuservices.net/DemoDownlo...ressorDemo.exe
Gas Expander
Gas Expander is a powerful, user friendly, program for the analysis of expansion turbines. An expansion turbine (Turboexpander)
is a device for converting the energy of a gas or vapor stream into mechanical work as the gas or vapor expands through the
turbine. The expansion process occurs rapidly, and heat transferred to or from the gas is usually very small. Consequently, the
exit temperature of the gas may be quite low. This feature allows the expander to find application as a component of refrigeration
systems. The other use of Turboexpanders is in power recovery. When a large flow of gas is reduced from a high pressure to
some lower pressure, or when high-temperature process streams are available at moderate pressures, the energy can be
recovered to drive pumps, fans, etc.
http://www.cuservices.net/DemoDownlo...panderDemo.exe
Fan
This program calculates the power required for a fan moving air or any kind of gas mixture. It predicts the change of flow, head,
power & sound level resulting from a change of fan speed or inlet temperature. A side calculation allows the properties of any gas
mixture to be calculated so that they can be used as inputs to the main fan program.
Gas Turbine
This program calculates the performance of a gas turbine using actual air enthalpy values. It provides values for the compressor
power, the turbine power, efficiency and fuel required.
http://www.cuservices.net/DemoDownloads/gtdemo.exe
Power and Propulsion Systems Analysis - Version A
Engineering Software has developed a new Windows based software package, Power and Propulsion Systems Analysis, that
quickly, easily and reliably calculates thermodynamic and transport properties of gaseous, liquid and solid species, analyzes
power cycles, power cycle components/processes and compressible flow.
management of power and propulsion systems. It should provide the user with the opportunity to more quickly, easily and
effectively do his/her work, explore more options, save time and give more confidence in carrying out engineering calculations.
Power Cycles
Power Systems Analysis
Engineering Software has developed a new Windows based software package, Power Systems Analysis, that quickly, easily and
reliably calculates thermodynamic and transport properties of gaseous, liquid and solid species, analyzes power cycles and
power cycle components/processes.
management of power systems. It should provide the user with the opportunity to more quickly, easily and effectively do his/her
Gas Dynamics
Engineering Software has developed a new Windows based software package, Gas Dynamics, that quickly, easily and reliably
calculates thermodynamic and transport properties of gaseous, liquid and solid species, analyzes power cycles, power cycle
management of propulsion systems. It should provide the user with the opportunity to more quickly, easily and effectively do
Mechanical Engineering II Add-On
Three classic mechanical electronic reference books are packaged together to deliver key areas in mechanical engineering.
These titles have been entirely updated with a new interface and added features that take advantage of Mathcad's new calculation
and browsing capabilities. Because they are delivered electronically for use within Mathcad, you can apply these resources
everyday with ease. And explanatory ************ and examples give you detailed background and guidance when you want it. Best of all,
each title comes with word search, a hyperlinked table of contents and hyperlinked indexing.[/B][/CENTER
[/CENTER]
آخر مواضيعي 0 مفاجأه كبيييييييره جدااا solidworks v2009 علي الرابيد شير
0 إقتراح أتمني أن يكون مهم
0 جدييييييييييييييد تعليم انفينتور جديييييييييييييد
قديم 12-04-2008, 01:08   #5
واخيرا يممكنكم زيارة هذا الموقع
http://www.jorcad.com/mechanical_software.html
آخر مواضيعي 0 استفتاء علي افضل برامج التصميم
0 SolidWorks 2010 SP0.0 Multilanguage Editions Win32/64
0 Mechanical Engineering Software
0 fluent6.4
قديم 12-04-2008, 07:48   #6
Newhak is on a distinguished road
May ALLAH bless you my beloved brother
آخر مواضيعي 0 Delcam Exchange V5.3.0105
0 ProgeCAD 2008 Professional v8.0.14
0 Maple 11 Professional
0 WaveMetrics IGOR Pro v6.02
0 Mathworks Matlab R2007b DVD
Newhak غير متواجد حالياً   رد مع اقتباس
قديم 14-04-2008, 02:59   #7
الصورة الرمزية kaiser
kaiser is on a distinguished road
جزاك الله خيرا
kaiser غير متواجد حالياً   رد مع اقتباس
قديم 14-04-2008, 03:40   #8
احمد عبد السلام is on a distinguished road
بارك الله فيكم
احمد عبد السلام غير متواجد حالياً   رد مع اقتباس
قديم 15-04-2008, 12:02   #9
احمدالسيدموسى is on a distinguished road
ماشى ياخميس هاشوف حاطيط اية بس لو اى كلام هضبطك فى الكلية
احمدالسيدموسى غير متواجد حالياً   رد مع اقتباس
قديم 15-04-2008, 12:06   #10
بصراحة انا غلط معاك انت راجل تستحق الشكر
engineering, mechanical, software
Mechanical Tolerance Stackup and Analysis (Mechanical Engineering (Marcell Dekker)) م/محمد لطفي كتب هندسة - Engineering books 2 19-04-2009 05:06
Mechanical Properties of Polymers and Composites (Mechanical Engineering (Marcell De م/محمد لطفي كتب هندسة - Engineering books 2 28-03-2009 11:45
Nonlinear Oscillations in Mechanical Engineering م/محمد لطفي كتب هندسة - Engineering books 0 22-05-2008 11:26
Mechanical Life Cycle Handbook (Mechanical Engineering م/محمد لطفي كتب هندسة - Engineering books 0 11-05-2008 10:47
Energy Conversion (Mechanical Engineering) م/محمد لطفي كتب هندسة - Engineering books 0 07-04-2008 08:44
الساعة الآن 08:29.
