![]() تاريخ التسجيل: 03 2010
اجعل جهازك يعمل بسلاسه عن طريق استخدام هذا برنامج error Repair professional 4.0.2 الذي يقوم بعمليات المسح ، وتحديد وتنظيف واصلاح الاخطاء مع بنقره واحدة. مع بضع خطوات سهلة ، سوف يمسح كامل السجل ويقدم قائمة باخطاء السجل . بعد ذلك يمكنك ان تختار بشكل انتقائي تنظيفه لكل بند من البنود تلقائيا او اصلاحها جميعا. سمات برنامج error Repair professional 4.0.2 : . مسح السجل للعثور على إدخالات غير صحيحة . إزالة الأخطاء في السجل . آلية ويدوية (للمستخدمين المتقدمين) . العمل السريع . واجهة سهلة الاستخدام 95 % of All PCs Have Hidden Errors on Them! Let Us Scan Your PC and Discover How Many Errors Are Lurking Inside It..." "Eliminate Them Instantly and Have The Peace Of Mind Knowing Your PC is Automatically Kept error Free, 24 Hours A Day!" Keep your PC operating smoothly by using error Repair professional to scan, identify, clean and Repair errors in your PC with a single click. With a few easy steps, it will scan your entire registry for any invalid entries and provides a List of the registry errors found. You can then choose to Selectivly clean each item or automatically Repair them all. Error Repair professional ia registry cleaner that uses high-performance error identification algorithms to quickly identify missing and invalid references in your Windows registry. It will safely clean and Repair Windows registry problems with a few simple clicks and enable you to enjoy a cleaner and more efficient PC. error Repair professional will guarantee that you eliminate errors in the nerve center of your PC. Windows Registry is the nerve center of your PC and problems with the Windows Registry are a common cause of Windows crashes and error messages. These problems can occur for many reasons including uninstalling Software with poor un-installation routines, by missing or corrupt hardware drivers, improperly deleting files and orphaned startup programs. By using error Repair professional regularly to fix error in Windows registry, your system should not only be more stable but it will also help Windows boot faster. The Windows registry is a database which stores settings and options for the operating system for Microsoft Windows 32-bit versions, 64-bit versions. It contains information and settings for all the hardware, software, users, and preferences of the PC. Whenever a user makes changes to "Control Panel" settings, or file associations, system policies, or installed software, the changes are reflected and stored in the registry. OS : Windows All تاريخ الاصدار : 24/7/2009 الحجم : 1.35 MB فقط ! ![]() تحميل البــــــــرامـــــــــــج للتحميل بأقصى سرعة وفك الضغط بسهولة يجب تحميل Winrar و IDM من هنـــــــــــا شرح تصطيب البرنامج من هنــــا او هنــــا او هنــــا او هنــــا ال****************** مرفق مع البرنامج Ziddu http://1tool.biz/164144 Slingfile http://1tool.biz/164140 Rapidshare http://1tool.biz/164141 IFile http://1tool.biz/164145 Sendspacce http://1tool.biz/164146 Load.To http://1tool.biz/164148 Megashares http://1tool.biz/164149 Bandago http://1tool.biz/164152 المصدر: منتدى المهندس كوم كلية الهندسة |
| 4.0.2, برنامج, error, professional, repair |
| Error Repair Professional 4.1.8 لمعالجة اخطاء الكمبيوتر | Cleaner | منتدى البرامج الحصرية | 3 | 25-04-2010 02:26 |
| برنامج Error Repair Professional 3.9.6 3.9.6 لاصلاح الأخطاء في الكمبيوتر باخر اصدار | Avatar | منتدى البرامج العام | 0 | 30-12-2009 03:24 |
| Error Repair Professional 4.1.1 | لا تنسى ذكرالله | منتدى البرامج العام | 1 | 20-12-2009 11:04 |
| صلح 95 % من أخطاء نظامك مع Error Repair Professional | أستغفرالله | منتدى البرامج العام | 0 | 16-10-2009 09:07 |
| لازالة اخطاء الجهاز Error Repair Professional 4.0.2 | EL MAGIC | منتدى البرامج العام | 1 | 27-07-2009 02:21 |
