| برامج هندسية - Engineering programmes البرامج الهندسية - برامج هندسة - اوتوكاد 2009 pspice archicad - electronic work bench - microsoft projec - staad matlab - mathcad -sap2000 |
![]() ![]() ![]() تاريخ التسجيل: 12 2006
MSC Marc 2007 R1 | 795 MB
Finite element analysis (FEA) is a critical part of the virtual design process. But because most FEA programs are linear, they can only study parts that deform a small amount, certainly not enough to deformation to exceed the linear elastic range of the materials. But Marc has no such limitations. A nonlinear FEA program, Marc enables you to assess the structural integrity and performance of parts undergoing large permanent deformations as a result of thermal or structural load. The types of deformations the program can study include geometric nonlinearities (metals bending) and material nonlinearities (elastomers and metals that yield under structural or thermal loading). You can also use Marc to simulate deformable, part-to-part or part-to-self contact under varying conditions that include the effects of friction—critical for analyzing nonlinear behavior in tool-and-die set-up, spring coil clash, or a windshield wiper system. And whether you are designing with glass, rubber, steel, or concrete, Marc offers an extensive library of metallic and non-metallic material models, along with a library of 175 elements for structural, thermal, and fluid analysis. Combine with pre- and post-processors You can drive all Marc products through the common GUI offered by Patran or Marc Mentat, two pre- and post processors that work with Marc. Mentat also provides the unique ability to process large problems in parallel using the domain decomposition technique. Loading conditions can originate from physical tests or virtual tests using Adams. MSC Software AFEA is a bundled version of Patran and Marc. Download http://www.filefactory.com/file/7c2336/ http://www.filefactory.com/file/d1ea29/ http://www.filefactory.com/file/4b4882/ http://www.filefactory.com/file/0eccf4/ http://www.filefactory.com/file/d1a645/ http://www.filefactory.com/file/e072c8/ http://www.filefactory.com/file/b5204e/ http://www.filefactory.com/file/b901e7/ المصدر: منتدى المهندس كوم كلية الهندسة |
![]() تاريخ التسجيل: 11 2007
مشكووووووووووووووووووووووووووووووووووووووور
شكرا على جهودكم المتميزة ...
جزاك كل خير
![]() تاريخ التسجيل: 12 2007
جزاك الله كل خير
![]() ![]() ![]() ![]() ![]() ![]() ![]() تاريخ التسجيل: 08 2007
![]() واضافه البرنامج خاص بعمل محاكاه مثلا لنظام تريد حله يقوم البرنامج بتطبيق اما finite volume method او finite surface وبالتالي يقوم بتقسيم النظام اللي
مجمومه صغيره جدا من الelement ويقوم بحلها حسب التطبيق هل هي خاصه بانتقال الحراره او سريان الموائع او الstreeses on body وهكذا ويقوم باخراج نتائج قريبه من الواقع ده اذا قمت بتنفيذ النظام عمليا وشكرا مره تانيه والبرنامج حلقه من سلسله لمجموعه برامج الfinite ومنها Ansys و alghor وغيرهم كتير |
مشكوووووووووور
اللهم ثبت قلوبنا على الإيمان واجزي بالخير كل رجل إحسان
god bless you
![]() تاريخ التسجيل: 01 2008
شكككككككككككككككككككرررررررررررررررررررررررراااااا ااااااااااااااااااااااا
| محل, مسائل, element, finite |
| An Introduction to Nonlinear Finite Element Analysis | م/محمد لطفي | كتب هندسة - Engineering books | 5 | 24-05-2011 04:28 |
| Finite Element Methods | عبقرينـو | كتب هندسة - Engineering books | 1 | 24-05-2011 04:25 |
| finite element method | قدوتي النبي | الهندسة المدنية - Civil Engineering | 0 | 03-10-2009 01:52 |
| Programming the Finite Element Method, 4th ed. | م/محمد لطفي | كتب هندسة - Engineering books | 7 | 22-04-2009 12:16 |
| Finite Element كتاب مميز | المشاغب | كتب هندسة - Engineering books | 3 | 22-04-2009 12:15 |
