![]() ![]() ![]() ![]() ![]() ![]() ![]() تاريخ التسجيل: 09 2007
![]() التفاصيل Chapter 1. Introduction 1.1 Chapter 2. Psychrometrics 2.1 Chapter 3. Heat and Moisture Transfer through Building Envelope 3.1 Chapter 4. Indoor and Outdoor Design Conditions 4.1 Chapter 5. Energy Management and Control Systems 5.1 Chapter 6. Load Calculations 6.1 Chapter 7. Water Systems 7.1 Chapter 8. Heating Systems, Furnaces, and Boilers 8.1 Chapter 9. Refrigerants, Refrigeration Cycles, and Refrigeration Systems 9.1 Chapter 10. Refrigeration Systems: Components 10.1 Chapter 11. Refrigeration Systems: Reciprocating, Rotary, Scroll, and Screw 11.1 vii Chapter 12. Heat Pumps, Heat Recovery, Gas Cooling, and Cogeneration Systems 12.1 Chapter 13. Refrigeration Systems: Centrifugal 13.1 Chapter 14. Refrigeration Systems: Absorption 14.1 Chapter 15. Air Systems: Components—Fans, Coils, Filters, and Humidifiers 15.1 Chapter 16. Air Systems: Equipment—Air-Handling Units and Packaged Units 16.1 Chapter 17. Air Systems: Air Duct Design 17.1 Chapter 18. Air Systems: Space Air Diffusion 18.1 Chapter 19. Sound Control 19.1 Chapter 20. Air Systems: Basics and Constant-Volume Systems 20.1 Chapter 21. Air Systems: Variable-Air-Volume Systems 21.1 Chapter 22. Air Systems: VAV Systems—Fan Combination, System Pressure, and Smoke Control 22.1 Chapter 23. Air Systems: Minimum Ventilation and VAV System Controls 23.1 Chapter 24. Improving Indoor Air Quality 24.1 Chapter 25. Energy Management and Global Warming 25.1 Chapter 26. Air conditioning Systems: System Classification, Selection, and Individual Systems 26.1 viii *******S Chapter 27. Air conditioning Systems: Evaporative Cooling Systems and Evaporative Coolers 27.1 Chapter 28. Air conditioning Systems: Space conditioning Systems 28.1 Chapter 29. Air conditioning Systems: Packaged Systems and Desiccant-Based Systems 29.1 Chapter 30. Air conditioning Systems: Central Systems and Clean-Room Systems 30.1 Chapter 31. Air conditioning Systems: Thermal Storage Systems 31.1 Chapter 32. Commissioning and Maintenance 32.1 Appendix A. Nomenclature and Abbreviations A.1 Appendix B. Psychrometric Chart, Tables of Properties, and I-P Units to SI Units Conversion B.1 Index follows Appendix B http://www.megaupload.com/?d=S3M5TNHR المصدر: منتدى المهندس كوم كلية الهندسة |
![]() تاريخ التسجيل: 10 2007
thank you brother
جزاك الله الف خير:d
merciiiiiiiiiiiiiiiiiiiiiiiii
![]() ![]() ![]() ![]() ![]() ![]() ![]() تاريخ التسجيل: 08 2007
مشكور اخي محمد وبارك الله فيك واعتذر لجميع الاعضاء عن تاخري بسبب اقتراب امتحاناتي واتمني منكم الدعاء لي بالتوفيق
عمل رائع جزاك اللة خيرا
![]() ![]() الله ينور جزاك الله خيرا |
شكرا جزيلا
| air, conditioning, كتاب |
| حمل كتاب Air Conditioning Engineering, Fifth Edition | المصري | الهندسة الميكانيكية - Mechanical Engineering | 24 | 30-05-2009 04:57 |
| كتاب Handbook of Air Conditioning and Refrigeration | م/محمد لطفي | كتب هندسة - Engineering books | 3 | 03-05-2009 05:56 |
| كتاب اتفضلوه Wet Cooling Towers,Air conditioning overview | mtzkhirt | الهندسة الميكانيكية - Mechanical Engineering | 6 | 22-04-2009 10:50 |
| كتاب Automotive Air Conditioning and Climate Control Systems | محمد أبوزهرة | هندسة السيارات - Automotive Engineering | 10 | 14-04-2009 07:23 |
| حمل كتاب Handbook of Heating, Ventilation, and Air Conditioning | المصري | هندسة التبريد والتكييف | 12 | 12-04-2009 12:01 |
