قديم 02-10-2007, 04:12   #1
Thumbs up كتاب انظمة التكييف والتبريد ASHRAE Handbook - HVAC Systems & Equipment 2004
كتاب انظمة التكييف والتبريد ashrae handbook 2004 - hvac systems & equipment
الانظمة والاجهزة للتكييف والتبريد ashrae handbook 2004 - hvac systems & equipment
2004 ashrae handbook - hvac systems & Equipment
2004 ashrae handbook - hvac systems and equipment
Table of *******s
This volume helps system designers and operators in selecting and using equipment, by providing in-depth de******************ions of features and differences of a wide variety of common systems, and the equipment (components or assemblies) that comprise them.
AIR-CONDITIONING AND HEATING systems
Chapter 1. hvac System Analysis and Selection
2. Building Air Distribution
3. In-Room Terminal Systems
4. Central Cooling and Heating
5. Decentralized Cooling and Heating
6. Panel Heating and Cooling
7. Cogeneration systems and Engine and Turbine Drives
8. Applied Heat Pump and Heat Recovery Systems
9. Design of Small Forced-Air Heating and Cooling Systems
10. Steam Systems
11. District Heating and Cooling
12. Hydronic Heating and Cooling System Design
13. Condenser Water Systems
14. Medium- and High-Temperature Water Heating Systems
15. Infrared Radiant Heating
AIR-HANDLING equipment
Chapter 16. Duct Construction
17. Room Air Distribution Equipment
18. Fans
19. Evaporative Air-Cooling Equipment
20. Humidifiers
21. Air-Cooling and Dehumidifying Coils
22. Desiccant Dehumidification and Pressure Drying Equipment
23. Air-Heating Coils
24. Air Cleaners for Particulate Contaminants
25. Industrial Gas Cleaning and Air Pollution Control
HEATING equipment
Chapter 26. Automatic Fuel-Burning Equipment
27. Boilers
28. Furnaces
29. Residential In-Space Heating Equipment
30. Chimney, Gas Vent, and Fireplace Systems
31. Unit Ventilators, Unit Heaters, and Makeup Air Units
32. Hydronic Heat-Distributing Units and Radiators
33. Solar Energy Equipment
GENERAL COMPONENTS
Chapter 34. Compressors
35. Condensers
36. Cooling Towers
37. Liquid Coolers
38. Liquid-Chilling Systems
39. Centrifugal Pumps
40. Motors, Motor Controls, and Variable-Speed Drives
41. Pipes, Tubes, and Fittings
42. Valves
43. Heat Exchangers
44. Air-to-Air Energy Recovery
UNITARY equipment
Chapter 45. Unitary Air Conditioners and Heat Pumps
46. Room Air Conditioners and Packaged Terminal Air Conditioners
47. Mechanical Dehumidifiers and Heat Pipes
حمل من هنا :
http://www.megaupload.com/?d=Y1RKD564
لفك الضغط :
http://www.allislam.net/vb
بعد الانتهاء من التحميل انسخها على cd وافتح الكتاب من هناك
مقول للامانة
آخر مواضيعي 0 جهاز bosch kts 530 للبيع بسعر مغرى
0 Basic English Grammar
0 موسوعة القران الشاملة
0 حمل منولات هوندا Honda service manuals
0 كورس الجامعه الأمريكيه كامل والروابط 100% شغالة
قديم 04-10-2007, 01:57   #2
آخر مواضيعي 0 Gas conditioning and processing, volume 4: Gas and liquid sweetening
0 Oxford English for Electrical and Mechanical Engineering
0 Fault Diagnosis of Analog Integrated Circuits
0 Control of Risk - A Guide to the Systematic Management of Risk from Construction
0 Solid Surfaces, Interfaces and Thin Films
قديم 04-10-2007, 02:06   #3
مشكور اخي محمد وحبيت اضيف نفس الكتاب بالطبعه 2005
ASHRAE Handbook :SI Edition
http://mihd.net/hun18s
pass: www.w5a.us
آخر مواضيعي 0 Studies in Optics
0 Plastics Technician's Toolbox: Vol. 1-5
0 Foundations of Engineering Acoustics
0 IEEE 551-2006 (Violet Book): Calculating Short Circuit Currents in Industrial and Co
0 Maynard's Industrial Engineering Handbook
قديم 04-10-2007, 04:00   #4
آخر مواضيعي 0 كتاب AIR- Conditioning
0 Engineering Drawing for Manufacture
0 مجموعة Tell Me More لتعليم 9 لغات
0 LANGMaster English Reading Courses + Dictionary 13CD
0 استطلاع بخصوص اجهزة التشخيص
قديم 10-10-2007, 12:07   #5
jamalmit is on a distinguished road
جزاك الله خيراًز ولكن لا استطيع تنزيل الكتاب الرجاء المساعدة
jamalmit غير متواجد حالياً   رد مع اقتباس
قديم 24-10-2007, 08:35   #6
lidabas is on a distinguished road
مرسىىىىىىىىىىىىىىىىىىىىىىىىىىىىىىىى
lidabas غير متواجد حالياً   رد مع اقتباس
قديم 05-11-2007, 08:32   #7
fadhl17 is on a distinguished road
شكرا لك على هذه الخدمه
fadhl17 غير متواجد حالياً   رد مع اقتباس
قديم 05-11-2007, 10:40   #8
abohikal is on a distinguished road
thxxxxxxxxxxx
abohikal غير متواجد حالياً   رد مع اقتباس
قديم 09-11-2007, 07:49   #9
kmbs is on a distinguished road
مشكور على مجهودك
kmbs غير متواجد حالياً   رد مع اقتباس
قديم 12-11-2007, 12:46   #10
Abu Elkheer is on a distinguished road
جزاك الله خيرا أخى الفاضل على تلك الخدمة العظيمة
Abu Elkheer غير متواجد حالياً   رد مع اقتباس
2004, ashrae, التكييف, انظمة, equipment, handbook, hvac, systems, والتبريد, كتاب
اهم كتاب في التبريد و التكييف (ashrae) م/سامرغازى هندسة التبريد والتكييف 25 02-05-2009 02:02
HVAC Systems and Components Handbook محمد أبوزهرة كتب هندسة - Engineering books 18 22-04-2009 11:00
HVAC Systems and Components Handbook م/محمد لطفي كتب هندسة - Engineering books 4 22-04-2009 08:54
2008 ASHRAE Handbook - HVAC: Systems and Equipment (SI Edition) م/محمد لطفي كتب هندسة - Engineering books 5 22-04-2009 06:17
2007 ASHRAE Handbook HVAC Application (SI Edition) م/محمد لطفي كتب هندسة - Engineering books 2 08-04-2009 02:03
الساعة الآن 04:29.
