برنامج Alldata 9.90 2008
قديم 19-01-2009, 11:18   #1
افتراضي برنامج Alldata 9.90 2008
Alldata 9.90 2008
95.14 GB
برابط تورنت
Professional repair shops need current, factory-correct information to meet the complex repair demands of today's automotive industry.
ALLDATA 9.90 shops have fast access to the industry's best information for vehicles from 1982 to present including TSBs, maintenance schedules, manufacturer recall information, OE solutions, and factory images and diagrams.
ALLDATA 9.9 DVD, the leading computer-based diagnostic, repair and estimating information system, can help you boost shop performance and build customer loyalty as you efficiently repair more makes and reduce comebacks.
• The most comprehensive information for 1982 to present vehicles, updated quarterly
• OEM images, diagrams and diagnostic flow charts
• Parts and labor information
• Maintenance schedules
• Manufacturer TSBs and Recalls
• Integrated estimating software
• OEM wiring diagrams with connector, ground, power distribution and splice information
• A2Z™ Component Search - the fastest route available to component information
Whether you measure productivity by the number of vehicles repaired in a day, the variety of vehicles you're able to work on, or the time spent on diagnosis and repair, using the right information and shop management tools is vital to the success of your business. alldata can help you succeed in every way.
Automotive repair shops that use the alldata system have a clear differentiation from other repair facilities. ALLDATA-equipped shops can provide their customers with the most accurate repair estimates and proof of diagnostic and repair procedures.
ALLDATA also includes factory-correct maintenance schedules that itemize additionally needed services.
Moreover, alldata helps shops build consumer confidence and loyalty
رابط التحميل تورنت فى الرابط التالى
باسورد فك الضغط
www.eng2all.com/vb
رابط تحميل رابط التورنت
http://www.eng2all.com/v.php?id=158
آخر مواضيعي 0 من واقع الحياة العملية
0 Industrial Gas Turbines
0 Automobildesign und Technik. Formgebung, Funktionalität
0 Spider-Man_3
0 جهاز bosch kts 530 بسعر مغرى داخل مصر
التعديل الأخير تم بواسطة محمد أبوزهرة ; 19-01-2009 الساعة 11:30
قديم 20-01-2009, 07:37   #2
خالدجبر is on a distinguished road
افتراضي رد: برنامج Alldata 9.90 2008
الاخ محمد ابو زهره شكر خاص لك مني على جهدك الرائع
آخر مواضيعي 0 خدمة مني لزوار الموقع
0 تبادل خبرات
0 تبادل خبرات
خالدجبر غير متواجد حالياً   رد مع اقتباس
قديم 20-01-2009, 07:42   #3
الأخ محمد ارغب في الحصول على هذا البرنامجAll data 2008 ارجو منك المساعده ومراسلتي على هذا الإيميل khalid-sa-2008************************.com
آخر مواضيعي 0 تبادل خبرات
0 تبادل خبرات
قديم 25-03-2009, 04:45   #4
الزعبي1 is on a distinguished road
شو المحتويات
الزعبي1 غير متواجد حالياً   رد مع اقتباس
قديم 25-03-2009, 05:41   #5
مهدي2000 is on a distinguished road
مشكور اخي الكريم
مهدي2000 غير متواجد حالياً   رد مع اقتباس
قديم 26-03-2009, 04:06   #6
hicham is on a distinguished road
choukrane jazilane
hicham غير متواجد حالياً   رد مع اقتباس
قديم 26-03-2009, 05:26   #7
الصورة الرمزية pipo_DFZ
pipo_DFZ is on a distinguished road
اين الرابط انا اريد البرنامج علي التورانت
آخر مواضيعي 0 Multi-Diag® Office I-2009 (16.11)
0 موضوع مهم لن تندم
0 المنتدي العربي الاكثر تنضيما
0 Mise a jour Multi-Di@g
0 auta data 3.22 (2009)
pipo_DFZ غير متواجد حالياً   رد مع اقتباس
قديم 26-03-2009, 08:17   #8
salahintel is on a distinguished road
شكرااااااااااااااااااااااااااااااااااااا
salahintel غير متواجد حالياً   رد مع اقتباس
قديم 26-03-2009, 08:28   #9
الصورة الرمزية م/سامرغازى
تم شكره 41 مرة في 23 مشاركة
بارك الله فيك
آخر مواضيعي 0 تركيب الأقمار الصناعية
0 التشلر ودوائر التحكم لها ارجو اللاستفادة
0 الموقع الرسمي لنتائج امتحانات جامعة كفر الشيخ
0 برنامج صيانه وتصميم لاجهزة التشلر
0 أنظمة التحكم والحمايات التي يجب أن تتوفر بوحدة التكييف
قديم 28-03-2009, 01:37   #10
derradji is on a distinguished road
مشكككككككككور يا اخي
derradji غير متواجد حالياً   رد مع اقتباس
2008, 9.90, 990, alldata, برنامج
برنامج ALLData الإصدار الاخير abdotop777 هندسة السيارات - Automotive Engineering 6 19-05-2012 01:28
اذا بحاجة الى برنامج alldata 2010 bassam.1977 هندسة السيارات - Automotive Engineering 1 01-12-2010 09:24
برنامج Alldata Dvd 8.50 محمد أبوزهرة هندسة السيارات - Automotive Engineering 49 11-07-2009 09:09
ممكن المساعدة بخصوص برنامج alldata abcd2008 هندسة السيارات - Automotive Engineering 4 10-04-2009 09:45
الساعة الآن 05:59.
