![]() ![]() تاريخ التسجيل: 12 2006
تم شكره 5 مرة في 4 مشاركة
اخوانى الاعزاء اقدم لكم اليوم برنامج مميز لاصلاح الريجستير ![]() Registry Check and Repair Most of the commonly used sections of your windows Registry will be checked here. The invalidate key entries will be listed after checking, so you may select and remove them from your registry. Registry Help can optimize, check, repair and manage your registry. That will solve many problems in your system, such as some crashes, system error messages, unexpected web visit and advertisement; also, it will improve the performance and stability of your operating system again. Moreover, it will search and find the NULL keys that may be unused or obsolete for your computer, then clean them to free more space and resource in your computer. Registry Tweak List The list of useful tweaks related to the windows registry. By adjusting the corresponding value in registry, it will implement the changes of the properties, so that to optimize your system. Registry Browser and Edit You can browse and edit the windows Registry as you browse your computer in the windows explorer. You can go back or forward when browsing, you can add keys to the favorite, and you can edit the data of key value here. The modifications will be recorded in the History. Moreover, you can easily locate the current browsing key entry in the windows regedit by just one clicking. Registry Search Registry Help has an advanced windows Registry search engine. The result will be gathered and displayed in the list. The comment for each item in the list will tell you where the key words are found, in key name, in value name, or in value data. You can select and delete the key entries directly form this result list. Also, it's convenient to switch between this search result and Reg Browser for editing them by clicking the Locate button. Registry History Here are the Registry modification records when you use Registry Help to change the windows registry. All the modification will be recorded when you remove key entries in "Check and Repair", edit. Here are some key features of "Registry Help": · Registry Help / Pro provides three types of scan: standard scan, complete scan and custom scan. · Windows Registry clean and repair · Registry tweak, tell you more tweaks about Windows registry. · Advanced search engine. Keyword list support. · Registry History. Changes are recorded by date and time with detailed de******************ion. · Advanced Windows Registry favorite list. · Automatic online update Download File المصدر: منتدى المهندس كوم كلية الهندسة |
| 1.62, 162, ممتاز, لاصلاح, الريجستير, برنامج, حصريا, registry |
| برنامج Argente Registry Cleaner 2.0.0.5 لاصلاح اخطاء الكمبيوتر وتسريع الجهاز | همسات الامل | منتدى البرامج العام | 3 | 12-11-2010 10:18 |
| Registry Mechanic 9.0.0.120 لاصلاح وتنظيف مفاتيح الريجستري التالفه باحدث اصدار | volume | منتدى البرامج العام | 0 | 10-12-2009 10:37 |
| Registry Clean Expert 4.76 لاصلاح مشاكل الريسجتري | za2zo2 | منتدى البرامج العام | 0 | 09-11-2009 03:05 |
| حصريا PC Tools Registry Mechanic 9.0.0.914 لاصلاح وتنظيف مفاتيح الريجستري | za2zo2 | منتدى البرامج العام | 0 | 28-10-2009 02:21 |
| Registry Mechanic 9.0.0.114 لاصلاح وتنظيف مفاتيح الريجستري التالفه | Bondo2 | منتدى البرامج العام | 0 | 15-10-2009 03:37 |
